With simple 0U and 1U installation options, HPE Basic Power Distribution Units are available in multiple form factors allowing you to configure access to power in your rack where you need it the most. HPE Basic PDUs provide a low-profile single-piece design allowing easy access to rear devices for maintenance. Vertical PDUs can be installed on either side of the rack with outlets facing the back of the rack for easy access and improved clearance. For higher power density configurations, they can be installed side by side on both sides of the rack with the outlets facing towards the center. Horizontal/Modular PDUs offer a modular architecture designed for data center customers who want to maximize power distribution and space efficiencies. The Control Unit or core can be mounted in any 1U space or in 0U space on the side of HPE Racks between the RETMA rails. Extension Bars mount directly to the frame so you can configure access to power where you need it.
Powerfully Built Power Distribution, Because no two Environments are the Same
HPE Basic Power Distribution Units are backed by a 3-year warranty. Quality, guaranteed.Premium materials and robust construction guarantee power continuity and maintained performance at elevated temperatures.HPE Basic Power Distribution Units include vertical and horizontal models with power output options ranging from 1.9kVA to 22kVA.Single and three-phase models to meet all your facility power needs. -
Our Basic PDUs get Power where you Need it to Go – and Keep it There
HPE Basic Power Distribution Units Horizontal/Modular PDU Models can be installed in any U position in your rack.Integrated cord retention to connect the right cord to the right outlet, quickly and easily. -
Vertical PDU Models use Button and Keyhole Mounting for Simple Drop in Install
HPE Basic Power Distribution Units vertical form factor models have a wide range of single and three-phase options providing up to 22kVA of output power.Mounts vertically on either side in the rear of the rack using industry standard button and keyhole mounting. Standard mounting faces the outlet towards the rear of the rack preventing interference in the maintenance zone between rear RETMA rails.Using the optional configuration of facing the outlets into the rack, multiple PDUs can be mounted on one side of the rack for higher power density. -
Getting Power Where it Needs to go has Never Been Easier, from Purchase to Prime Time
HPE Basic Power Distribution Units have a wide range of mounting options to fit every application. Power where you need it, plus more room for compute.Highest-density PDUs on market means more power and less headache for even the most demanding compute applications.Tool-less installation, low profile and modular extensions simplify configuration and reduce time to deployment.HPE Foundation Care means your power isn't the only thing that's protected – the warranty from your HPE servers extends to your PDUs.
- HPE Basic Power Distribution Unit 1U/0U - power distribution unit - 3680 VA
- Power distribution unit - rack-mountable
- 2.1 kg
- Localisation
- Worldwide
- Input Voltage
- AC 200-240 V
- Output Voltage
- AC 200-240 V
- Power Capacity
- 3680 VA
- Input Connectors
- 1 x power IEC 60320 C20
- Output connectors
- 12 x power IEC 60320 C13
- 44.45 cm x 15.3 cm x 4.2 cm
- Designed For
- HPE 600, 800; 11000 G2 Series; Advanced Series Racks 42U 600; Apollo 4510 Gen9; ProLiant c3000, DL120 Gen9, DL160 Gen9, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL360p Gen8, DL380 Gen9, DL60 Gen9, DL80 Gen9, e2000 G6, m350, m400, m710, m800, ML10 v2, ML150 Gen9, ML350 Gen9, ML350p Gen8
- Localisation
- Worldwide
- Input Voltage
- AC 200-240 V
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 200-240 V
- Max Electric Current
- 16 A
- Power Capacity
- 3680 VA
- Circuit Protection
- Circuit breaker
- Cables Included
- No power cord is included
- Rack Mounting Kit
- Included
- UL, TUV, cUL, KC
- 10 °C
- 50 °C
- 10 - 90%
- 44.45 cm
- 15.3 cm
- 4.2 cm
- 2.1 kg
- Designed For
- HPE 600mm x 1075mm Advanced Pallet Rack, 600mm x 1075mm Advanced Shock Rack, 600mm x 1075mm Enterprise Crate Rack, 600mm x 1075mm Enterprise Pallet Rack, 600mm x 1075mm Enterprise Shock Rack, 600mm x 1200mm Advanced Pallet Rack, 600mm x 1200mm Advanced Shock Rack, 600mm x 1200mm Enterprise Air Duct Rack, 600mm x 1200mm Enterprise Pallet Rack, 600mm x 1200mm Enterprise Shock Network Rack, 600mm x 1200mm Enterprise Shock Rack, 600mm x 1200mm Grey Enterprise Air Duct Rack, 600mm x 1200mm Grey Enterprise Shock Rack, 600mm x 1200mm Network Advanced Shock Rack, 800mm x 1075mm Enterprise Pallet Rack, 800mm x 1075mm Enterprise Shock Rack, 800mm x 1200mm Advanced Pallet Rack, 800mm x 1200mm Advanced Shock Rack, 800mm x 1200mm Enterprise Pallet Rack, 800mm x 1200mm Enterprise Shock Network Rack, 800mm x 1200mm Enterprise Shock Rack, 800mm x 1200mm Grey Enterprise Shock Network Rack, 800mm x 1200mm Grey Enterprise Shock Rack, 800mm x 1200mm Network Advanced Shock Rack , HPE 11000 G2 Series 11642 1075mm Pallet Universal Rack , HPE Advanced Series Racks 42U 600mm x 1075mm Kitted Advanced Pallet Rack with Side Panels and Baying, 42U 600mm x 1075mm Kitted Advanced Shock Rack with Side Panels and Baying , HPE Apollo 4510 Gen9 , HPE ProLiant c3000, DL120 Gen9, DL120 Gen9 Entry, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL160 Gen9 Performance, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL20 Gen9, DL20 Gen9 Entry, DL20 Gen9 Performance, DL320e Gen8 v2 Entry, DL360 Gen9 Performance, DL360p Gen8, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, e2000 G6, m350, m400, m710, m800, ML10 v2, ML10 v2 Base, ML10 v2 Entry, ML10 v2 Performance, ML150 Gen9, ML150 Gen9 Base, ML150 Gen9 Entry, ML150 Gen9 Performance, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, ML350p Gen8
