HPE 2TB 6G SATA 7.2K 2.5IN 512E
Quicklinx: C746WS00 Mfr#: 765455-B21
Form Factor: 2.5" SFF
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 2TB
Spin Speed (rpm): 7200rpm
Hurry, only 1 left in stock!
£340.76 ex VAT
£408.91 inc VAT
Do you have non mission-critical applications that require economical high capacity and reliability hard disk drives? HPE Server SATA Hard Drives are built for reliability and larger capacity needs for today's non mission-critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE Server SATA Hard Drives are available in both 3.5-inch Large Form Factor (LFF) and 2.5-inch Small Form Factor (SFF) and ship with a standard one-year warranty. All Hewlett Packard Enterprise hard drives pass a rigorous qualification process, which certify that every drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE Server SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
  • Designed and Engineered to Provide High Capacity and Reliable Secure Storage
    HPE Server Midline Hard Drives are ideal for bulk data storage, cloud and web infrastructure environments.Broad portfolio of optimized solutions provide up to 10 TB of storage, and growing in a single device.Rotational Vibration Sensors deliver enhanced rotational vibration tolerance that provides enterprise class reliability in midline drives.Available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) in a wide variety of capacity points.Prevent unauthorized access to your data with HPE Digitally Signed Firmware. It provides the security and assurance that drive firmware comes from a trusted source and protects against malicious attacks.
  • Support Entry/SMB servers with value priced drives
    HPE Server Midline Hard Drives have lower start-up costs without sacrificing reliability at the lowest $/GB.Non-mission critical hard drives at the lowest $/GB.6 Gb/sec data transfer rate to support existing servers.
HPE Midline - hard drive - 2 TB - SATA 6Gb/s
Hard drive - hot-swap - advanced format 512e
2 TB
2.5" SFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
Advanced format 512e
1-year warranty
Bundled with
HP SmartDrive carrier
ProLiant BL460c Gen10, BL660c Gen9, DL180 Gen10, DL180 Gen9, DL20 Gen10, DL20 Gen9, DL325 Gen10, DL360 Gen10, DL380 Gen10, DL385 Gen10, DL388 Gen10, DL388 Gen9, DL560 Gen10, DL560 Gen9, ML110 Gen10, ML110 Gen9, ML30 Gen10, ML30 Gen9, ML350 Gen10, XL230a Gen9, XL250a Gen9; StoreEasy 1850; Synergy 480 Gen10, 660 Gen10
2 TB
2.5" SFF
SATA 6Gb/s
Bytes per Sector
512
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" SFF
Limited warranty - 1 year
HPE ProLiant BL460c Gen10 (2.5"), DL180 Gen10 SMB (2.5"), DL20 Gen10 (2.5"), DL20 Gen10 Entry (2.5"), DL20 Gen10 Performance (2.5"), DL20 Gen10 solution (2.5"), DL20 Gen9 Solution (2.5"), DL325 Gen10 Base (2.5"), DL325 Gen10 Plus (2.5"), DL325 Gen10 Solution (2.5"), DL360 Gen10 Entry (2.5"), DL360 Gen10 High Performance (2.5"), DL360 Gen10 Low (2.5"), DL360 Gen10 SMB (2.5"), DL360 Gen10 Solution (2.5"), DL380 Gen10 Entry (2.5"), DL380 Gen10 Entry SMB (2.5"), DL380 Gen10 for Cohesity DataPlatform (2.5"), DL380 Gen10 High Performance (2.5"), DL380 Gen10 Network Choice (2.5"), DL380 Gen10 Network Choice for SAP HANA Compute Block (2.5"), DL380 Gen10 Performance (2.5"), DL380 Gen10 SMB (2.5"), DL380 Gen10 Solution (2.5"), DL385 Gen10 (2.5"), DL385 Gen10 Base (2.5"), DL385 Gen10 Entry (2.5"), DL385 Gen10 High-Performance (2.5"), DL385 Gen10 Performance (2.5"), DL385 Gen10 Plus (2.5"), DL385 Gen10 Plus Entry (2.5"), DL385 Gen10 SMB (2.5"), DL385 Gen10 Solution (2.5"), DL388 Gen10 (2.5"), DL560 Gen10 Base (2.5"), DL560 Gen10 Performance (2.5"), ML110 Gen10 Solution (2.5"), ML30 Gen10 (2.5"), ML30 Gen10 Entry (2.5"), ML30 Gen10 Performance (2.5"), ML30 Gen10 Solution (2.5"), ML30 Gen9 Entry (2.5"), ML30 Gen9 Solution (2.5"), ML350 Gen10 (2.5"), ML350 Gen10 Base (2.5"), ML350 Gen10 Entry (2.5"), ML350 Gen10 High Performance (2.5"), ML350 Gen10 Performance (2.5"), ML350 Gen10 Solution (2.5"), ML350 Gen10 Special Server (2.5"), ML350 Gen10 Sub-Entry (2.5") , HPE Synergy 480 Gen10 Base Compute Module (2.5"), 480 Gen10 Entry Compute Module (2.5"), 480 Gen10 Performance Compute Module (2.5"), 480 Gen10 Premium Backplane Compute Module (2.5"), 480 Gen10 Standard BackPlane Compute Module (2.5"), 480 Gen10 w/o Drives Compute Module (2.5"), 660 Gen10 Base Compute Module (2.5"), 660 Gen10 Compute Module (2.5"), 660 Gen10 Entry Compute Module (2.5"), 660 Gen10 Performance Compute Module (2.5"), 660 Gen10 Premium Compute Module (2.5")
Type: Hard drive
Capacity: 2TB
Brand: HPE
Price Range Ex VAT: 300 - 500
