Do your servers need reliable, economical, high capacity Midline hard drives for your growing storage workload needs? HPE Server Midline Hard Drives deliver the highest capacity, performance and reliability to your datacenter applications. Midline hard drives allow you to store more data without sacrificing performance or reliability; they are ideal to store all your bulk storage requirements. HPE Server Midline Hard Drives are available in both 3.5-inch Large Form Factor (LFF) and 2.5-inch Small Form Factor (SFF) and ship with a standard one-year warranty. All HPE hard drives pass a rigorous qualification process, which certify that every drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE Server Midline Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
Smart carriers
HPE Hard Drives with smart carriers are designed to provide an interface to communicate critical status and management information. System status LED icons and a spinning activity ring reflecting the data-writing process notify users of the current system status. A blue LED located behind the handle can be activated remotely to guide users to a specific drive tray, while a do-not-remove icon positioned on the tray's eject button lights up to warn users when the removal of the drive would cause data loss. -
Helium drives
Although hard drives are sealed, they have air inside. Air can create turbulence-induced risk vibrations which can limit the storage density of HDDs. Newer helium-filled drives virtually eliminate turbulence because helium is 1/7th as dense as air. This lower density allows the read/write mechanism to spin more easily and precisely, with less drag. Less internal turbulence means the drive platters can be closer together, allowing more platters and increasing the capacity potential in the same space. Less turbulence also means helium drives tend to use less power, and run cooler and quieter.
- HPE Midline - hard drive - 2 TB - SAS 12Gb/s
- Hard drive - hot-swap - Digitally Signed Firmware
- Capacity
- 2 TB
- Form Factor
- 3.5" LFF
- Interface
- SAS 12Gb/s
- Data Transfer Rate
- 1.2 GBps
- Spindle Speed
- 7200 rpm
- 1-year warranty
- Bundled with
- HPE SmartDrive carrier
- Designed For
- HPE D3600; ProLiant DL20 Gen9, DL360 Gen10, DL380 Gen10, DL385 Gen10, DL388 Gen10, DL388 Gen9, DX360 Gen10, DX380 Gen10, ML30 Gen9; StoreEasy 1450
- Capacity
- 2 TB
- Form Factor
- 3.5" LFF
- Interface
- SAS 12Gb/s
- Bundled with
Performance
- Drive Transfer Rate
- 1.2 GBps (external)
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x SAS 12 Gb/s
- Compatible Bay
- 3.5" LFF
- Limited warranty - 1 year
- Designed For
- HPE D3600 , HPE ProLiant DL20 Gen9 Solution (3.5"), DL360 Gen10 (3.5"), DL360 Gen10 Base (3.5"), DL360 Gen10 Entry (3.5"), DL360 Gen10 High Performance (3.5"), DL360 Gen10 Low (3.5"), DL360 Gen10 Network Choice (3.5"), DL360 Gen10 Performance (3.5"), DL360 Gen10 SMB (3.5"), DL360 Gen10 SMB Network Choice (3.5"), DL360 Gen10 Solution (3.5"), DL380 Gen10 (3.5"), DL380 Gen10 All Flash Server for Datera (3.5"), DL380 Gen10 Base (3.5"), DL380 Gen10 Entry (3.5"), DL380 Gen10 Entry SMB (3.5"), DL380 Gen10 for Cohesity DataPlatform (3.5"), DL380 Gen10 High Performance (3.5"), DL380 Gen10 Hybrid Server for Datera (3.5"), DL380 Gen10 Network Choice (3.5"), DL380 Gen10 Network Choice for CTERA (3.5"), DL380 Gen10 Network Choice for SAP HANA Compute Block (3.5"), DL380 Gen10 Performance (3.5"), DL380 Gen10 Server for CTERA (3.5"), DL380 Gen10 SMB (3.5"), DL380 Gen10 SMB Networking Choice (3.5"), DL380 Gen10 Solution (3.5"), DL385 Gen10 (3.5"), DL385 Gen10 Base (3.5"), DL385 Gen10 Entry (3.5"), DL385 Gen10 High-Performance (3.5"), DL385 Gen10 Performance (3.5"), DL385 Gen10 SMB (3.5"), DL385 Gen10 Solution (3.5"), DL388 Gen10 (3.5"), DL388 Gen9 (3.5"), DL388 Gen9 Base (3.5"), DX360 Gen10 (3.5"), DX380 Gen10 (3.5"), ML30 Gen9 Entry (3.5"), ML30 Gen9 Solution (3.5") , HPE StoreEasy 1450
