HPE 2915-8G-PoE Switch
Quicklinx: 72Z8WS00 Mfr#: J9562A
The Aruba 2915 Switch Series provides simple, cost-effective and reliable access layer connectivity for enterprises, branch offices and SMBs. This compact and quiet 8-port, fully managed, Basic Layer 3, Gigabit Ethernet switch with PoE is ideal for deployment in open areas, offices and environments. A robust Basic Layer 3 feature set supports static and RIP routing, sFlow, ACLs, rate limiting, IPv6 and PoE. It is easy to use and deploy, supporting PoE devices and can be managed with the optional HPE Intelligent Management Center (IMC) Software for a single view of your entire network.
  • Compact and Reliable Gigabit Access Layer Switch with PoE
    The Aruba 2915 Switch provides simple, cost-effective and reliable access layer connectivity for enterprises, branch offices and SMBs.This compact and quiet, 8-port fully managed Basic Layer 3 Gigabit Ethernet switch with PoE is ideal for deployment in open areas, offices and environments with limited space or are acoustically sensitive.Robust Basic Layer 3 feature set includes support for static and RIP routing, sFlow, ACLs, rate limiting, IPv6, and PoE.Eight Gigabit Ethernet PoE ports with two, additional, dual-personality Gigabit Ethernet ports provide copper or SFP connectivity for a total of ten ports.Single view of the entire network with the optional HPE Intelligent Management Center (IMC) Software.
  • Security and Quality of Service (QoS)
    The Aruba 2915 Switch supports flexible authentication methods including Local MAC, 802.1X, MAC, and Web for greater, policy-driven application security.The Aruba 2915 Switch supports advanced denial of service (DOS) protection, such as DHCP, Dynamic ARP, and Dynamic IP lockdown, and flexible traffic controls including ACLs and QoS.Traffic prioritization with IEEE 802.1p allows real-time traffic classification with support for eight priority levels mapped to two or four queues.Rate limiting and flow control help ensure reliable communications.Defend your IPv6 network with DHCPv6 Protection.
  • Simple Deployment and Management
    The Aruba 2915 Switch supports a choice of management interfaces with Web GUI, command-line interface (CLI) and SNMP.The Aruba 2915 Switch Series can be seamlessly managed with the optional HPE Intelligent Management Center (IMC) Software to provide end-to-end network transparency with consistent network experience through comprehensive configuration, compliance and policy management.RMON and sFlow provide advanced monitoring and reporting capabilities for statistics, history, alarms, and events.The Aruba 2915 Switch Series is compact and fanless for quiet and unobtrusive operation in open spaces, conference rooms and offices. Flexible deployment with wall, table, and rack mounting options.Convenient LEDs provide quick status of fault and power and per port status of activity, speed, and full-duplex operation.
HPE Aruba 2915-8G-PoE - switch - 8 ports - Managed
Switch - 8 ports - Managed - stackable
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
MAC Address Table Size
8K entries
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP
Flow control, DHCP support, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), port mirroring, manageable, IPv6 support, sFlow, Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
16 cm x 9 cm x 4.5 cm
1.7 kg
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
PoE
8K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
1 x Freescale
RAM
128 MB DDR2 SDRAM
Flash Memory
32 MB Flash
Status Indicators
Port transmission speed, link/activity
8 x 1000Base-T RJ-45 , 2 x 1000Base-T RJ-45 , 1 x console RJ-45 management , 2 x SFP (mini-GBIC)
External power adapter
Rack Mounting Kit
Included
FCC Class A certified, CISPR 22 Class A, CISPR 24, EN 60950, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, IEC 60950, EN55024, UL 60950, CSA 22.2 No. 60950
16 cm
9 cm
4.5 cm
1.7 kg
45 °C
15 - 95%
