HPE 1TB SATA HDD 7200RPM 2.5" SFF
Quicklinx: BQTXWS00 Mfr#: 656108-001
HPE Midline - Hard Drive - 1 TB - SATA 6Gb/s
Designed for: ProLiant BL420c Gen8, BL460c Gen8, BL465c Gen8, BL660c Gen8, DL160 Gen8, DL360e Gen8, DL360p Gen8, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen8, MicroServer Gen8, ML110e Gen8, ML310e Gen8, ML350e Gen8, ML350p Gen8, SL210t Gen8, SL230s Gen8, SL250s Gen8, SL270s Gen8, SL4540 Gen8, WS460c Gen
  • Smart carriers
    HPE Hard Drives with smart carriers are designed to provide an interface to communicate critical status and management information. System status LED icons and a spinning activity ring reflecting the data-writing process notify users of the current system status. A blue LED located behind the handle can be activated remotely to guide users to a specific drive tray, while a do-not-remove icon positioned on the tray's eject button lights up to warn users when the removal of the drive would cause data loss.
  • Helium drives
    Although hard drives are sealed, they have air inside. Air can create turbulence-induced risk vibrations which can limit the storage density of HDDs. Newer helium-filled drives virtually eliminate turbulence because helium is 1/7th as dense as air. This lower density allows the read/write mechanism to spin more easily and precisely, with less drag. Less internal turbulence means the drive platters can be closer together, allowing more platters and increasing the capacity potential in the same space. Less turbulence also means helium drives tend to use less power, and run cooler and quieter.
HPE Midline - hard drive - 1 TB - SATA 6Gb/s
Hard drive - hot-swap
1 TB
2.5" SFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
Bundled with
HP SmartDrive carrier
ProLiant BL420c Gen8, BL460c Gen8, BL465c Gen8, BL660c Gen8, DL160 Gen8, DL360e Gen8, DL360p Gen8, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL388p Gen8, DL560 Gen8, MicroServer Gen8, ML110e Gen8, ML310e Gen8, ML350e Gen8, ML350p Gen8, SL210t Gen8, SL230s Gen8, SL250s Gen8, SL270s Gen8, SL4540 Gen8, WS460c Gen8
1 TB
2.5" SFF
SATA 6Gb/s
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" SFF
HPE ProLiant BL420c Gen8 (2.5"), BL460c Gen8 (2.5"), BL465c Gen8 (2.5"), BL660c Gen8 (2.5"), BL660c Gen8 Performance (2.5"), DL360e Gen8 (2.5"), DL360e Gen8 Base (2.5"), DL360e Gen8 Entry (2.5"), DL360e Gen8 Performance (2.5"), DL360e Gen8 Special Server (2.5"), DL360p Gen8 (2.5"), DL360p Gen8 CMS (2.5"), DL360p Gen8 Performance (2.5"), DL380e Gen8 (2.5"), DL380e Gen8 Base (2.5"), DL380e Gen8 Entry (2.5"), DL380e Gen8 High Performance (2.5"), DL380e Gen8 Storage (2.5"), DL380p Gen8 Performance (2.5"), DL380p Gen8 Special (2.5"), DL385p Gen8 (2.5"), DL385p Gen8 Dedicated Workload (2.5"), DL385p Gen8 Entry (2.5"), DL385p Gen8 Maximized Consolidation (2.5"), DL385p Gen8 Storage (2.5"), DL385p Gen8 Storage Centric (2.5"), DL388p Gen8 Base (2.5"), DL560 Gen8 (2.5"), DL560 Gen8 Base (2.5"), DL560 Gen8 Entry (2.5"), DL560 Gen8 Performance (2.5"), MicroServer Gen8 (2.5"), MicroServer Gen8 Base (2.5"), MicroServer Gen8 Base Starter Kit (2.5"), MicroServer Gen8 Entry (2.5"), ML110e Gen8 (2.5"), ML310e Gen8 (2.5"), ML310e Gen8 Base (2.5"), ML310e Gen8 Entry (2.5"), ML310e Gen8 Performance (2.5"), ML350e Gen8 (2.5"), ML350e Gen8 Base (2.5"), ML350e Gen8 Entry (2.5"), ML350e Gen8 Performance (2.5"), ML350e Gen8 v2 (2.5"), ML350p Gen8 (2.5"), ML350p Gen8 Special Server (2.5"), SL210t Gen8 (2.5"), SL210t Gen8 1U Node (2.5"), SL230s Gen8 1U Left Half Width Tray (2.5"), SL250s Gen8 2U Left Half Width Tray (2.5"), SL250s Gen8 2U PCIe Gen3 Left Tray (2.5"), SL250s Gen8 2U PCIe Gen3 Right Tray (2.5"), SL250s Gen8 Base 2U Left Half Width Tray (2.5"), SL250s Gen8 Base 2U Right Half Width Tray (2.5"), SL270s Gen8 1U Left Half Width Tray (2.5"), SL270s Gen8 1U Right Half Width Tray (2.5"), SL270s Gen8 Base 4U Left Half Width Tray (2.5"), SL270s Gen8 Base 4U Right Half Width Tray (2.5"), SL270s Gen8 SE 4U Left Tray (2.5"), SL270s Gen8 SE 4U Right Tray (2.5"), SL4540 Gen8 (2.5"), SL4540 Gen8 Tray 2x Node Server (2.5"), WS460c Gen8 (2.5")
