Your basket is empty
HPE 1TB 6G SATA 7200rpm LFF 3.5" Non-hot plug Midline HDD
Quicklinx: 8LNRWS00 Mfr#: 659337-B21
Form Factor: 3.5" LFF
Type: Hard drive
Interface Type: Serial ATA-300
Capacity: 1TB
Spin Speed (rpm): 7200rpm
£104.28 ex VAT
£125.13 inc VAT
Do you have non-mission critical applications that require economical high capacity and reliability hard disk drives? HPE SATA Hard Drives are built for reliability and larger capacity needs for today's non-mission critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE SATA Hard Drives are available in both Large Form Factor (LFF) (3.5-inch) and Small Form Factor (SFF) (2.5-inch) and ship with a standard one-year warranty. All HPE hard drives pass a rigorous qualification process, which certify that every HPE drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
HPE Midline - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
3.5" LFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
1 year warranty
ProLiant DL160 Gen8, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL80 Gen9, MicroServer Gen8, ML10 Gen9, ML10 v2, ML110 Gen9, ML310e Gen8, ML350e Gen8
1 TB
3.5" LFF
SATA 6Gb/s
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" LFF
1 year warranty
Limited warranty - 1 year
HPE ProLiant DL160 Gen8 (3.5"), DL160 Gen8 Base (3.5"), DL160 Gen8 Entry (3.5"), DL160 Gen8 Performance (3.5"), DL180 Gen9 (3.5"), DL180 Gen9 Base (3.5"), DL180 Gen9 Entry (3.5"), DL180 Gen9 Storage (3.5"), DL20 Gen9 (3.5"), DL20 Gen9 Entry (3.5"), DL20 Gen9 Performance (3.5"), DL320e Gen8 (3.5"), DL320e Gen8 Base (3.5"), DL320e Gen8 Entry (3.5"), DL320e Gen8 Performance (3.5"), DL320e Gen8 v2 Base (3.5"), DL80 Gen9 (3.5"), DL80 Gen9 Entry (3.5"), MicroServer Gen8 (3.5"), MicroServer Gen8 Base (3.5"), MicroServer Gen8 Base Starter Kit (3.5"), MicroServer Gen8 Entry (3.5"), MicroServer Gen8 Performance, ML10 Gen9 (3.5"), ML10 Gen9 Entry (3.5"), ML10 Gen9 Performance (3.5"), ML10 v2 (3.5"), ML10 v2 Base (3.5"), ML10 v2 Entry (3.5"), ML10 v2 Performance (3.5"), ML110 Gen9 (3.5"), ML110 Gen9 Base (3.5"), ML110 Gen9 Entry (3.5"), ML310e Gen8 (3.5"), ML310e Gen8 Base (3.5"), ML310e Gen8 Entry (3.5"), ML310e Gen8 Performance (3.5"), ML310e Gen8 v2 (3.5"), ML310e Gen8 v2 Base (3.5"), ML310e Gen8 v2 Enty (3.5"), ML310e Gen8 v2 Performance (3.5"), ML350e Gen8 (3.5"), ML350e Gen8 Base (3.5"), ML350e Gen8 Entry (3.5"), ML350e Gen8 Performance (3.5"), ML350e Gen8 v2 (3.5"), ML350e Gen8 v2 Base (3.5"), ML350e Gen8 v2 Entry (3.5")
Type: Hard drive
Capacity: 1TB
Brand: HPE
Price Range Ex VAT: 100 - 150
