HPE 16GB DDR4 DIMM 288-pin 2133 MHz/PC4-17000 CL15 1.2V registered ECC
Quicklinx: C4N7WS00 Mfr#: 726719-B21
Does your server have the memory it needs to perform as its role expands over time? When you choose HPE DDR4 SmartMemory, you get great performance, reliability, and efficiency that provides the compatibility, capacity and bandwidth you need to productively manage your expanding workload with the HPE ProLiant Gen9 server, Apollo Family, Synergy and Blade Systems. The quality and reliability of DRAM are more important now than ever, as data center trends such as server virtualization, cloud computing, the use of large database applications, have all increased the need for higher capacity memory with greater uptime. HPE SmartMemory goes through rigorous qualification and testing processes that unlock extended memory performance features available only with Hewlett Packard Enterprise Gen9 servers. This extensive testing ensures that HPE server memory is completely compatible with and optimized for HPE servers.
  • High Performance
    HPE DDR4 2400 MT/s server memory provides up to a 23% increase in throughput at DDR4-2400 MT/s in comparison to DDR4 2133 MT/s memory modules.HPE DDR4 2400 MT/s server memory provides a 14 to 33% improvement in memory performance depending on platform and configuration in comparison to DDR4 2133 MT/s memory modules.HPE DDR4 2400 MT/s server memory provides up to a 25% improvement in latency at DDR4-2400 MT/ s in comparison to DDR4 2133 MT/s memory modules.HPE DDR4 2400 MT/s server memory provides a 100% increase in maximum memory capacity with the introduction of the 128GB LRDIMM.
  • High Reliability
    HPE DDR4 SmartMemory modules have been tested and qualified on all HPE server platforms to ensure the highest level of signal integrity.HPE DDR4 SmartMemory prevents unnecessary DIMM replacement and reduces server downtime with advanced memory error detection technology.HPE server memory is made of the highest quality materials, reducing issues that may affect signal integrity, increasing system reliability.
  • Reducing Power Consumption
    HPE DDR4 2400 MT/s SmartMemory modules reduce power consumption by up to 20% in comparison to DDR4 2133 MT/s memory modules.HPE server memory speed targets provide customers with memory that performs above industry standards, allowing them to increase performance without having to increase the amount of memory purchased.
HPE - DDR4 - module - 16 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - registered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15 (15-15-15)
Dual rank, registered
Voltage
1.2 V
HP 726719-B21
Apollo 4200 Gen9, 4520 Gen9, 4530; ProLiant BL460c Gen9, BL660c Gen9, DL120 Gen9, DL160 Gen9, DL180 Gen9, DL360 Gen9, DL380 Gen9, DL388 Gen9, DL560 Gen9, DL580, DL580 Gen9, DL60 Gen9, DL80 Gen9, ML110 Gen9, ML150 Gen9, ML350 Gen9, WS460c Gen9, XL170r Gen9, XL190r Gen9, XL230a Gen9; StoreEasy 3850
16 GB
Upgrade Type
System specific
HP 726719-B21
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15 (15-15-15)
ECC
Chips Organization
X4
Voltage
1.2 V
HPE Apollo 4200 Gen9, 4200 Gen9 for Google, 4520 Gen9, 4530 , HPE ProLiant BL460c Gen9, BL460c Gen9 Base, BL460c Gen9 Entry, BL460c Gen9 Performance, BL660c Gen9, DL120 Gen9, DL120 Gen9 Entry, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL160 Gen9 Performance, DL160 Gen9 Thoughtspot Server, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL360 Gen9, DL360 Gen9 Base, DL360 Gen9 CMS, DL360 Gen9 Entry, DL360 Gen9 High Performance, DL360 Gen9 Performance, DL360 Gen9 Special Server, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL380 Gen9 Scale-up SAP HANA Tailored Datacenter Integration Compute Block, DL380 Gen9 Special, DL388 Gen9, DL388 Gen9 Base, DL560 Gen9, DL560 Gen9 Base, DL560 Gen9 Entry, DL560 Gen9 Performance, DL580 Gen9, DL580 Gen9 Base, DL580 Gen9 Database, DL580 Gen9 High Performance, DL580 Gen9 SAP HANA Scale-out Base Configuration, DL580 Gen9 SAP HANA Scale-up Base Configuration, DL580 Intel E7 8800v4 Scale-out SAP HANA Tailored Datacenter Integration Compute Block, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML150 Gen9, ML150 Gen9 Base, ML150 Gen9 Entry, ML150 Gen9 Performance, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, WS460c Gen9, WS460c Gen9 Graphics, WS460c Gen9 Graphics Expansion, XL170r Gen9, XL190r Gen9, XL230a Gen9 , HPE StoreEasy 3850 Gateway Single Node
