Your basket is empty
HPE 16GB 2RX4 PC3L-10600R-9 KIT
Quicklinx: 863XWS00 Mfr#: 647901-B21
Accessory Type: Memory
£138.07 ex VAT
£165.68 inc VAT
Is finding reliable DRAM memory for your HP ProLiant Gen8 Server series in your data center a major challenge? When you choose HP SmartMemory you get the same high quality, reliability, and confidence that come with your HP ProLiant Gen8 Server series. DRAM quality and reliability are more important now than ever. Industry trends such as server virtualization, cloud computing, the use of large database applications, and high-performance computing have all created demand for higher capacity memory with greater reliability and uptime. HP SmartMemory unlocks certain features available only with HP Qualified Server memory. HP SmartMemory enables ProLiant Gen8 Servers to reliably identify and verify whether installed memory has passed the rigorous HP qualification and testing processes. And because the memory is authenticated, you can enable extended memory performance features through the system ROM.
HPE Low Power kit - DDR3L - 16 GB - DIMM 240-pin
RAM memory
16 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1333 MHz (PC3L-10600)
Latency Timings
CL9
Dual rank, Low Voltage, registered
Voltage
1.35 V
HP 647901-B21
ProLiant BL420c Gen8, BL460c Gen8, BL660c Gen8, DL160 Gen8, DL360e Gen8, DL360p Gen8, DL380e Gen8, DL380p Gen8, ML350e Gen8, ML350p Gen8, SL230s Gen8, SL250s Gen8, SL270s Gen8, WS460c Gen8
16 GB
Upgrade Type
System specific
HP 647901-B21
DRAM
DDR3L SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9
ECC
Chips Organization
X4
Voltage
1.35 V
Compatible Slots
1 x memory - DIMM 240-pin
HPE ProLiant BL420c Gen8, BL460c Gen8, BL660c Gen8, DL160 Gen8 Base, DL160 Gen8 Entry, DL160 Gen8 Performance, DL360e Gen8, DL360e Gen8 Base, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL360p Gen8 Special Server, DL380e Gen8, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2 Base, ML350p Gen8, ML350p Gen8 Base, ML350p Gen8 Entry, ML350p Gen8 Performance, ML350p Gen8 Special Server, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, WS460c Gen8
Brand: HPE
Price Range Ex VAT: 100 - 150
