Maximize your PC performance with HP Memory. Upgrading your memory is a cost-effective way to boost your system performance without having to upgrade your processor.
High Performance
HPE DDR4 2400 MT/s server memory provides up to a 23% increase in throughput at DDR4-2400 MT/s in comparison to DDR4 2133 MT/s memory modules.HPE DDR4 2400 MT/s server memory provides a 14 to 33% improvement in memory performance depending on platform and configuration in comparison to DDR4 2133 MT/s memory modules.HPE DDR4 2400 MT/s server memory provides up to a 25% improvement in latency at DDR4-2400 MT/ s in comparison to DDR4 2133 MT/s memory modules.HPE DDR4 2400 MT/s server memory provides a 100% increase in maximum memory capacity with the introduction of the 128GB LRDIMM. -
High Reliability
HPE DDR4 SmartMemory modules have been tested and qualified on all HPE server platforms to ensure the highest level of signal integrity.HPE DDR4 SmartMemory prevents unnecessary DIMM replacement and reduces server downtime with advanced memory error detection technology.HPE server memory is made of the highest quality materials, reducing issues that may affect signal integrity, increasing system reliability. -
Reducing Power Consumption
HPE DDR4 2400 MT/s SmartMemory modules reduce power consumption by up to 20% in comparison to DDR4 2133 MT/s memory modules.HPE server memory speed targets provide customers with memory that performs above industry standards, allowing them to increase performance without having to increase the amount of memory purchased.
- HPE - DDR4 - 16 GB - DIMM 288-pin - registered
- Product Type
- RAM memory
- Capacity
- 16 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15 (15-15-15)
- Dual rank, registered
- Voltage
- 1.2 V
- OEM Manufacturer Equivalent Part Number
- HP 726719-B21
- Designed For
- Apollo 4520 Gen9, 4530; ProLiant BL460c Gen9, BL660c Gen9, DL160 Gen9, DL180 Gen9, DL360 Gen9, DL380 Gen9, DL388 Gen9, DL560 Gen9, DL580 Gen9, DL80 Gen9, ML110 Gen9, ML350 Gen9, WS460c Gen9, XL170r Gen9, XL190r Gen9, XL230a Gen9; StoreEasy 1850, 3850
- Capacity
- 16 GB
- Upgrade Type
- System specific
- HP 726719-B21
- DRAM
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL15 (15-15-15)
- ECC
- Chips Organization
- X4
- Voltage
- 1.2 V
- Designed For
- HPE Apollo 4520 Gen9, 4530 , HPE ProLiant BL460c Gen9, BL460c Gen9 Base, BL460c Gen9 Entry, BL460c Gen9 Performance, BL660c Gen9, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL360 Gen9, DL360 Gen9 Base, DL360 Gen9 CMS, DL360 Gen9 Entry, DL360 Gen9 Performance, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 Performance, DL388 Gen9, DL388 Gen9 Base, DL560 Gen9, DL560 Gen9 Base, DL560 Gen9 Entry, DL560 Gen9 Performance, DL580 Gen9, DL580 Gen9 Database, DL580 Gen9 SAP HANA Scale-up Base Configuration, DL80 Gen9, DL80 Gen9 Entry, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, WS460c Gen9 Graphics, WS460c Gen9 Graphics Expansion, XL170r Gen9, XL190r Gen9, XL230a Gen9 , HPE StoreEasy 1850, 3850 Gateway Single Node
