HPE 16GB (1x16GB) Dual Rank x4 PC3L-12800R (DDR3-1600) Mem Module
Quicklinx: 9JDQWS00 Mfr#: 713985-B21
Is finding reliable DRAM memory for your HP ProLiant Gen8 Server series in your data center a major challenge? When you choose HP SmartMemory you get the same high quality, reliability, and confidence that come with your HP ProLiant Gen8 Server series. DRAM quality and reliability are more important now than ever. Industry trends such as server virtualization, cloud computing, the use of large database applications, and high-performance computing have all created demand for higher capacity memory with greater reliability and uptime. HP SmartMemory unlocks certain features available only with HP Qualified Server memory. HP SmartMemory enables ProLiant Gen8 Servers to reliably identify and verify whether installed memory has passed the rigorous HP qualification and testing processes. And because the memory is authenticated, you can enable extended memory performance features through the system ROM.
  • High Performance
    HPE DDR3 SmartMemory performs to industry-defined specifications.HPE DDR3 SmartMemory has been tested and performance-tuned specifically for HPE ProLiant Server series, which ensures that HPE server memory is optimized for every HPE server.HPE DDR3 SmartMemory enables extended memory performance features through the system ROM.
  • High Reliability
    HPE DDR3 SmartMemory is made of the highest quality materials, reducing issues that affect signal integrity and increasing system reliability.
  • Improved Efficiency
    HPE DDR3 SmartMemory supports HPE servers at a lower price point.
HPE - DDR3L - module - 16 GB - DIMM 240-pin - 1600 MHz / PC3L-12800 - registered
Memory module
16 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11
Dual rank, Low Voltage, registered
Voltage
1.35 V
HP 713985-B21
ProLiant BL420c Gen8, BL460c Gen8, BL660c Gen8, DL360p Gen8, DL380e Gen8, DL380p Gen8, DL388p Gen8, DL560 Gen8, DL580 Gen8, ML350e Gen8, ML350p Gen8, SL210t Gen8, SL230s Gen8, SL250s Gen8, SL270s Gen8, SL4540 Gen8, WS460c Gen8
16 GB
Upgrade Type
System specific
HP 713985-B21
DRAM memory module
DDR3L SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Chips Organization
X4
Voltage
1.35 V
Compatible Slots
1 x memory - DIMM 240-pin
HPE ProLiant BL420c Gen8, BL460c Gen8, BL660c Gen8, BL660c Gen8 Entry, BL660c Gen8 Performance, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL360p Gen8 Special Server, DL380e Gen8, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Performance, DL380p Gen8 Special, DL388p Gen8 Base, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, DL580 Gen8, DL580 Gen8 Base, DL580 Gen8 High Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML350e Gen8 v2 Base, ML350e Gen8 v2 Entry, ML350p Gen8, ML350p Gen8 Base, ML350p Gen8 Entry, ML350p Gen8 Performance, ML350p Gen8 Special Server, SL210t Gen8, SL210t Gen8 1U Node, SL210t Gen8 2U Node, SL230s Gen8 1U Left Half Width Tray, SL230s Gen8 1U Left Tray, SL230s Gen8 1U Right Half Width Tray, SL230s Gen8 1U Right Tray, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL250s Gen8 2U Left Half Width Tray, SL250s Gen8 2U PCIe Gen3 Left Tray, SL250s Gen8 2U PCIe Gen3 Right Tray, SL250s Gen8 2U Right Half Width Tray, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Left Tray Server, SL250s Gen8 Base 2U Right Half Width Tray, SL250s Gen8 Base 2U Right Tray Server, SL250s Gen8 Left Tray, SL250s Gen8 Right Tray, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, SL270s Gen8 SE 4U Left Tray, SL270s Gen8 SE 4U Right Tray, SL4540 Gen8, SL4540 Gen8 Tray 1x Node Server, SL4540 Gen8 Tray 2x Node Server, SL4540 Gen8 Tray 3x Node Server, WS460c Gen8, WS460c Gen8 Graphics Expansion
