Boost the capabilities of your HP Workstation with registered DDR4 memory from HP. Get high reliability and cost savings on high-capacity modules vs. unregistered memory.
Maximize the newest processors
Keep the newest multi-core processors performing at their peak with fast memory. Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between several open applications. -
Benefit from integrated ECC
Help avoid errors that can corrupt data sets and introduce system issues when you select ECC memory, which includes Error Checking and Correcting technology to correct single-bit memory errors. -
Get HP-tested reliability
Ensure all of your memory characteristics match by upgrading with HP-branded memory that's been tested at the component level and to ensure seamless system-level integration with HP products. -
Supported by HP
Protect your investment with a warranty that is backed the same world-class HP service and support you get for your workstation.
- HP - DDR4 - module - 16 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - registered
- Product Type
- Memory module
- Capacity
- 16 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15
- Registered
- Voltage
- 1.2 V
- OEM Manufacturer Equivalent Part Number
- HP J9P83AA
- 1-year warranty
- Designed For
- Workstation Z440, Z640, Z840
- Capacity
- 16 GB
- Upgrade Type
- System specific
- HP J9P83AA
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL15
- ECC
- Registered
- Voltage
- 1.2 V
- 1-year warranty
- Designed For
- HP Workstation Z440, Z640, Z840
