Your basket is empty
HPE 15-in-1 USB2/3 3.5 Media Card Reader
Quicklinx: 9R95WS00 Mfr#: F4N90AA
Supported Formats: SDXC Memory Card
Interface: USB 3.0
£19.12 ex VAT
£22.94 inc VAT
Quickly and easily backup your files and transfer your data, pictures, video, and projects between your PC and 15 types of storage media with the HP 15-in-1 Media Card Reader.
HP 15-in-1 USB2/3 Media Card Reader - card reader - USB 3.0
Card reader - internal - 15 in 1
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, SDHC Memory Card, Memory Stick PRO-HG Duo, SDXC Memory Card, Memory Stick Select, SDHC UHS-II Memory Card
Host Interface
USB 3.0
Required Bay
3.5" internal
1 year warranty
EliteDesk 700 G1, 800 G1 (SFF, tower); ProDesk 400 G1 (micro tower, SFF), 405 G1 (micro tower), 490 G1 (micro tower), 600 G1 (SFF, tower)
Supported with Optional Adapter
miniSD, microSD, miniSDHC, Memory Stick Micro (M2), microSDHC
Host Interface
USB 3.0
Required Bay
3.5" internal
124.5 mm
101.6 mm
25.4 mm
0.16 kg
Required Ports
1 x 20 pin USB 3.0 header
Microsoft Windows XP Professional, Microsoft Windows 7 Home Basic, Microsoft Windows 7 Home Premium (32/64 bits), Microsoft Windows Vista Business (32/64 bits), Microsoft Windows 7 Professional (32/64 bits), Microsoft Windows 7 Ultimate (32/64 bits), Microsoft Windows Vista Home Basic 32-bit Edition, Windows 8 64-bit Edition, Windows 8 Pro 64-bit Edition, Microsoft Windows XP Home Edition (32 bit), Windows 8.1 64-bit Edition
5.25-inch bay adapter
VCCI, C-Tick, BSMI, cUL, WHQL, MIC, FCC, USB-IF, TUV T
Limited warranty - parts and labour - 1 year
HP EliteDesk 700 G1, 800 G1 (SFF, tower) , HP ProDesk 400 G1 (micro tower, SFF), 405 G1 (micro tower), 490 G1 (micro tower), 600 G1 (SFF, tower)
9R95 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.17
9R95 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.42
9R95 C2G 2-Port USB 2.0 Manual Switch In Stock £18.78
9R95 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £13.11
9R95 C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.18
9R95 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.20
9R95 C2G USB Superbooster Extender Kit In Stock £33.46
9R95 C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £35.26
Interface: USB 3.0
Brand: HPE
Price Range Ex VAT: 0 - 50
