Your basket is empty
HPE 1410-8G Switch - switch - 8 ports - unmanaged - desktop, wall-mountable
Quicklinx: 71NXWS00 Mfr#: J9559A
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: 1Gbps
Managed: No
£48.87 ex VAT
£58.64 inc VAT
The HPE 1410 Switch Series consists of unmanaged switches designed for small businesses looking for entry-level, low-cost, reliable networking solutions. Available features include flow control to provide outstanding data efficiency, simplified plug-and-play operation, Auto-MDIX, auto-speed negotiation, flexible mounting options, and Limited Lifetime Warranty. All models have Quality of Service (QoS) support and IEEE 802.3x flow control features. Plug-and-play convenience is enabled by auto-MDIX and auto-speed negotiation.
Switch - 8 ports - unmanaged
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
MAC Address Table Size
8K entries
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
AC 120/230 V ( 50/60 Hz )
15.6 cm x 9.7 cm x 2.5 cm
340 g
Enclosure Type
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
8K entries
Status Indicators
Link activity, port transmission speed, port duplex mode, status
8 x 1000Base-T - RJ-45
External power adapter
24 Watt
FCC Class A certified, VCCI, EN 60950, EN55022, ICES-003, IEC 60950, UL 60950, CSA 22.2 No. 60950, FCC Part 15 B
15.6 cm
9.7 cm
2.5 cm
340 g
15 - 95%
71NX C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £4.98
71NX C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.24
71NX C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.49
71NX C2G 2m Cat6a Shielded Patch - Blue In Stock £7.53
71NX C2G TruLink Media Gateway RJ45 Cap In Stock £0.59
71NX C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £47.82
Ports: 8
Managed: No
Brand: HPE
Price Range Ex VAT: 0 - 50
