HPE 1 TB -3.5" LFF SATA 6 7.2k Internal Hard Drive
Quicklinx: CW3QWS00 Mfr#: 843266-B21
Form Factor: 3.5" LFF
Type: Hard drive
Capacity: 1TB, 1TB
Spin Speed (rpm): 7200rpm
More than 50 in stock
£45.39 ex VAT
£54.46 inc VAT
Do you have non mission-critical applications that require economical high capacity and reliability hard disk drives? HPE Server SATA Hard Drives are built for reliability and larger capacity needs for today's non mission-critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE Server SATA Hard Drives are available in both 3.5-inch Large Form Factor (LFF) and 2.5-inch Small Form Factor (SFF) and ship with a standard one-year warranty. All Hewlett Packard Enterprise hard drives pass a rigorous qualification process, which certify that every drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE Server SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
  • Designed and Engineered to Provide High Capacity and Reliable Secure Storage
    HPE Server Midline Hard Drives are ideal for bulk data storage, cloud and web infrastructure environments.Broad portfolio of optimized solutions provide up to 10 TB of storage, and growing in a single device.Rotational Vibration Sensors deliver enhanced rotational vibration tolerance that provides enterprise class reliability in midline drives.Available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) in a wide variety of capacity points.Prevent unauthorized access to your data with HPE Digitally Signed Firmware. It provides the security and assurance that drive firmware comes from a trusted source and protects against malicious attacks.
  • Support Entry/SMB servers with value priced drives
    HPE Server Midline Hard Drives have lower start-up costs without sacrificing reliability at the lowest $/GB.Non-mission critical hard drives at the lowest $/GB.6 Gb/sec data transfer rate to support existing servers.
HPE Entry - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal - Native Command Queuing (NCQ)
1 TB
3.5" LFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
7.22 cm x 13.66 cm x 1.6 cm
1-year warranty
ProLiant DL20 Gen9, DL20 Gen9 Entry, DL20 Gen9 Performance, DL20 Gen9 Solution, MicroServer Gen10, MicroServer Gen10 Entry, MicroServer Gen10 Performance, MicroServer Gen10 Plus Entry, MicroServer Gen10 Plus Performance, MicroServer Gen10 Plus SMB, MicroServer Gen10 Solution, MicroServer Gen10 Stockage Collaboration, MicroServer Gen8 Performance, ML10 Gen9, ML10 Gen9 Entry, ML10 Gen9 Performance, ML10 v2, ML10 v2 Base, ML10 v2 Entry, ML10 v2 Performance, ML350 Gen10, ML350 Gen10 Base, ML350 Gen10 Entry, ML350 Gen10 High Performance (3.5"), ML350 Gen10 Performance (3.5"), ML350 Gen10 SMB (3.5"), ML350 Gen10 Solution (3.5"), ML350 Gen10 Special Server (3.5"), ML350 Gen10 Sub-Entry (3.5")
1 TB
3.5" LFF
SATA 6Gb/s
Bytes per Sector
512
7.22 cm
13.66 cm
1.6 cm
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
8.5 ms (average) / 18 ms (max)
Track-to-Track Seek Time
1 ms
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" LFF
Limited warranty - 1 year
5 °C
60 °C
HPE ProLiant DL20 Gen9 (3.5"), DL20 Gen9 Entry (3.5"), DL20 Gen9 Performance (3.5"), DL20 Gen9 Solution (3.5"), MicroServer Gen10 (3.5"), MicroServer Gen10 Entry (3.5" LFF), MicroServer Gen10 Performance (3.5" LFF), MicroServer Gen10 Plus Entry (3.5"), MicroServer Gen10 Plus Performance (3.5"), MicroServer Gen10 Plus SMB (3.5"), MicroServer Gen10 Solution (3.5"), MicroServer Gen10 Stockage Collaboration (3.5"), MicroServer Gen8 Performance (3.5" LFF), ML10 Gen9 (3.5"), ML10 Gen9 Entry (3.5"), ML10 Gen9 Performance (3.5"), ML10 v2 (3.5"), ML10 v2 Base (3.5"), ML10 v2 Entry (3.5"), ML10 v2 Performance (3.5"), ML350 Gen10 (3.5"), ML350 Gen10 Base (3.5"), ML350 Gen10 Entry (3.5"), ML350 Gen10 High Performance (3.5"), ML350 Gen10 Performance (3.5"), ML350 Gen10 SMB (3.5"), ML350 Gen10 Solution (3.5"), ML350 Gen10 Special Server (3.5"), ML350 Gen10 Sub-Entry (3.5")
Type: Hard drive
Capacity: 1TB
Capacity: 1TB
Brand: HPE
Price Range Ex VAT: 0 - 50
