Brand
HP ZVR Virtual Reality Display 3D LED 23.6" Monitor
Quicklinx: C9DWWS00 Mfr#: K5H59A4#ABU
Diagonal Size: 23.6in
Max Resolution: 1920 x 1080
Response Time: 5.6ms
Speakers: None
Interfaces: DVI, DisplayPort
£4,576.78 ex VAT
£5,492.13 inc VAT
Change the way you think, work, and create with the HP Zvr 59,94 cm (23.6') Virtual Reality Display, the first commercial 3D display from HP that delivers a virtual-holographic 3D image so you can see every angle and curve in lifelike detail.
  • Intuitive virtual reality
    Experience real-time, natural interaction with your 3D content as the Full HD stereoscopic display's full-motion parallax sensors track and respond to the movement of your lightweight, passive glasses.
  • Put a pen in it
    Rotate, manipulate, navigate, and zoom in and out of every detail of the holographic image with the stylus pen.
  • Redefine show and tell
    Project your 3D models to a 2D big screen for easy team collaboration using your choice of third-party hardware.
HP Zvr Virtual Reality Display - 3D LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
3D Capable
Yes (3D glasses included)
Stylus, 4 x IR cameras, USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 120 Hz
Pixel Pitch
0.272 mm
Brightness
200 cd/m²
Contrast Ratio
1000:1
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
DVI-D, DisplayPort
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare
Voltage
69 cm x 28.29 cm x 52.53 cm
9.1 kg
English / United Kingdom
Plug and Play, FCC Class A certified, CSA, UL
5-year warranty
Display Type
Diagonal Size
23.6"
3D Capable
3D Technology
Passive
Built-in Devices
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Pixel Per Inch
93.5
Brightness
200 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% NTSC
Vertical Refresh Rate
60 - 120 Hz
Horizontal Refresh Rate
24 - 80 kHz
Video Bandwidth
285.5 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
HDCP, Mercury free, 72% NTSC colour gamut
69 cm x 28.29 cm x 52.53 cm - with stand
9.1 kg
Input
Stylus
DVI-D (HDCP) , DisplayPort (HDCP) , 4 x USB 2.0 downstream , USB 2.0 upstream
Mechanical
Height, tilt
Tilt Angle
-7/+60
Height Adjustment
162 mm
VESA Mounting Interface
100 x 100 mm
Detachable stand, VESA interface support
1 x DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
30,000 hours
Input Voltage
Power Consumption (Typical)
90 Watt
Power Consumption Stand by
12 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities, Zvr System Software, Zvr Experience (Demo)
Microsoft Windows 7
Dimensions & Weight Details
With stand - width: 69 cm - depth: 28.29 cm - height: 52.53 cm - weight: 9.1 kg , Without stand - width: 69 cm - depth: 6.81 cm - height: 52.53 cm - weight: 5.92 kg
Limited warranty - 5 years - on-site - response time: next business day
5 °C
35 °C
20 - 80% (non-condensing)
Speakers: None
Interfaces: DVI
Interfaces: DisplayPort
Brand: HP
Price Range Ex VAT: £1500+
