HP Zbook x2 G4 Core i7-7500U 16GB 512GB SSD 14" Windows 10 Pro
Quicklinx: DVDGWS00 Mfr#: 2ZB81EA#ABU
Display Size: 14in
Processor Model: I7-7500U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB
Hard Drive Capacity: 512GB
  • Core i7
  • IEEE 802.11n
£2,505.69 ex VAT
£3,006.82 inc VAT
Introducing HP's most powerful detachable PC. With remarkable performance and versatility to push your favorite Adobe applications to the limit, no PC is better suited to turn your vision into reality.
  • Incredible Power for Limitless Creativity
    Easily work with high resolution files and switch between applications like Adobe Photoshop and Illustrator. Create effortlessly with quad-core Intel Core processors, twice the memory of any other HP detachable PC and NVIDIA 3D Graphics.
  • Multiple modes
    With the flexibility of a detachable Bluetooth keyboard, you can go from laptop to tablet whenever inspiration strikes. Plus customizable HP Quick Keys provide 18 time-saving shortcuts for your favorite Adobe apps.
  • Make every stroke count
    Create without interruption with a pen that never needs to be charged. It responds instantly to every nuance of your hand with 4,096 pressure sensitive levels and natural tilt capabilities.
HP ZBook x2 G4 Detachable Workstation - 14" - Core i7 7500U - 16 GB RAM - 512 GB SSD - UK
Tablet - with Bluetooth keyboard
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (7th Gen) 7500U / 2.7 GHz (3.5 GHz) / 4 MB Cache
16 GB DDR4 (2 x 8 GB)
Storage
512 GB SSD NVMe
Display
14" LED backlight touchscreen 3840 x 2160 / Ultra HD 4K
Graphics
NVIDIA Quadro M620 / Intel HD Graphics 620
Video Memory
2 GB GDDR5 SDRAM
Input Device
Detachable keyboard
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, NFC, Bluetooth 4.2
4-cell - up to 10 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
Dimensions (WxDxH) - tablet
36.45 cm x 22.7 cm x 1.46 cm
1.65 kg
Limited warranty - parts and labour - 3 years
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
Cache
L3 - 4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
16 GB (2 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2133 MHz
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
512 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe)
Display
14" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
3840 x 2160 (Ultra HD 4K)
Widescreen
Image Brightness
300 cd/m²
Colour Support
1 billion colours
High Bit Rate 2 (HBR2), Ultra HD 4K ultra wide-viewing angle (UWVA) anti-glare DreamColor
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Video System Features
NVIDIA Optimus, Shader Model 5.0
Camera
Yes - 720p (front)
Resolution
8 Megapixel (rear)
Video Resolutions
1280 x 720, 1920 x 1080
Frame Rate
30 frames per second
Camera Features
IR camera, low light enhancement, rear camera with auto focus, front camera with fixed focus
Sound
Stereo speakers, dual array microphone
Codec
Conexant CX7700
High Definition Audio
Audio Features
Bang & Olufsen Audio, Intel Smart Sound
Input
Detachable keyboard
Keyboard Backlight
Keyboard Layout
Volume control, ClickPad with gesture support, brightness adjustment, on/off touch, kickstand, HP Quick Key
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Miracast
IEEE 802.11, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
4-cell lithium polymer
70 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
90 Watt, 19.5 V
Connections & Expansion
USB 3.0 (charging) , 2 x USB-C 3.1/Thunderbolt 3/DisplayPort 1.2/VGA/HDMI (Power Delivery) , Headphone/microphone combo jack , HDMI
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Security
Power-on password, Intel Anti-Theft Technology (iAT), HP SpareKey, One-Step Logon, Setup Password, Automatic DriveLock, HP Drive Encryption, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, MST (multi-stream transport), Master Boot Record Security, Secure Erase
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion sensor
Security Slot Type
Kensington security slot
Power adapter, Bluetooth keyboard
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, KCC, A-Tick, ICES
Localization
1.65 kg
Dimensions (WxDxH) / Weight Details
36.45 cm x 22.7 cm x 1.46 cm / 1.65 kg - tablet , 36.45 cm x 22.7 cm x 2.03 cm / 2.17 kg - tablet with keyboard
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP Zbook x2 G4 Core i7-7500U 16GB 512GB SSD 14 Bundle deal on HP Zbook x2 G4 Core i7-7500U 16GB 512GB SSD 14" Windows 10 Pro
£2,685.55
saving £3.64
£2,604.86
Display Size: 14in
Optical Storage: None
Graphics: NVIDIA Quadro M620 / Intel HD Graphics 620
Hard Drive Type: SSD
Touchscreen: Yes
Type: Laptop
Brand: HP
Price Range Ex VAT: 1500+
