HP Zbook x2 Core i7-7500U 8GB 256GB SSD 14" Windows 10 Pro
Quicklinx: DWZ0WS00 Mfr#: 2ZB84EA#ABU
Display Size: 14in
Processor Model: I7-7500U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i7
  • IEEE 802.11n
£3,328.56 ex VAT
£3,994.27 inc VAT
Introducing HP's most powerful detachable PC. With remarkable performance and versatility to push your favorite Adobe applications to the limit, no PC is better suited to turn your vision into reality.
  • Incredible Power for Limitless Creativity
    Easily work with high resolution files and switch between applications like Adobe Photoshop and Illustrator. Create effortlessly with quad-core Intel Core processors, twice the memory of any other HP detachable PC and NVIDIA 3D Graphics.
  • Multiple modes
    With the flexibility of a detachable Bluetooth keyboard, you can go from laptop to tablet whenever inspiration strikes. Plus customizable HP Quick Keys provide 18 time-saving shortcuts for your favorite Adobe apps.
  • Make every stroke count
    Create without interruption with a pen that never needs to be charged. It responds instantly to every nuance of your hand with 4,096 pressure sensitive levels and natural tilt capabilities.
HP ZBook x2 G4 Detachable Workstation - 14" - Core i7 7500U - 8 GB RAM - 256 GB SSD - UK
Tablet - with Bluetooth keyboard
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (7th Gen) 7500U / 2.7 GHz (3.5 GHz) / 4 MB Cache
8 GB DDR4 (2 x 4 GB)
Storage
256 GB SSD NVMe, TLC
Display
14" LED backlight touchscreen 3840 x 2160 / Ultra HD 4K
Graphics
NVIDIA Quadro M620 / Intel HD Graphics 620
Video Memory
2 GB GDDR5 SDRAM
Input Device
Detachable keyboard
Keyboard
Keyboard Backlight
802.11a/b/g/n/ac, NFC, Bluetooth 4.2
4-cell - up to 10 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
Dimensions (WxDxH) - tablet
36.45 cm x 22.7 cm x 1.46 cm
1.65 kg
Limited warranty - parts and labour - 3 years
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
Cache
L3 - 4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (2 x 4 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2133 MHz
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe), triple-level cell (TLC)
RAID Level
RAID 0, RAID 1
Display
14" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
3840 x 2160 (Ultra HD 4K)
Widescreen
Image Brightness
300 cd/m²
Colour Support
1 billion colours
High Bit Rate 2 (HBR2), Ultra HD 4K ultra wide-viewing angle (UWVA) anti-glare DreamColor
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Video System Features
NVIDIA Optimus, Shader Model 5.0
Sound
Stereo speakers, microphone
Codec
Conexant CX7700
High Definition Audio
Audio Features
Bang & Olufsen Audio, Intel Smart Sound
Input
Detachable keyboard
Keyboard Backlight
Keyboard Layout
Volume control, ClickPad with gesture support, brightness adjustment, on/off touch, kickstand, HP Quick Key
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Miracast
IEEE 802.11, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
4-cell lithium polymer
70 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
90 Watt, 19.5 V
Connections & Expansion
USB 3.0 (charging) , 2 x USB-C 3.1/Thunderbolt 3/DisplayPort 1.2/VGA/HDMI (Power Delivery) , Headphone/microphone combo jack , HDMI
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Password Manager, Windows Defender, Device Access Manager, HP Velocity, HP PageLift, HP Security Manager, HP BIOS Configuration Utility (free download), HP Credential Manager, HP Client Catalogue (free download), HP Driver Packs, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP MIK for Microsoft SCCM (free download), HP Client Security Suite Gen3, Native Miracast, HP JetAdvantage, HP Workwise (free download), HP Management Integration Kit for Microsoft System Center Configuration Manager (free download), Adobe Creative Cloud Desktop Manager
Security
Power-on password, Intel Anti-Theft Technology (iAT), HP SpareKey, One-Step Logon, Setup Password, Automatic DriveLock, HP Drive Encryption, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, MST (multi-stream transport), Master Boot Record Security, Secure Erase
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion sensor
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, KCC, A-Tick, ICES
Localization
1.65 kg
Dimensions (WxDxH) / Weight Details
36.45 cm x 22.7 cm x 1.46 cm / 1.65 kg - tablet , 36.45 cm x 22.7 cm x 2.03 cm / 2.17 kg - tablet with keyboard
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP Zbook x2 Core i7-7500U 8GB 256GB SSD 14 Bundle deal on HP Zbook x2 Core i7-7500U 8GB 256GB SSD 14" Windows 10 Pro
£3,427.73
Display Size: 14in
Optical Storage: None
Graphics: NVIDIA Quadro M620 / Intel HD Graphics 620
Hard Drive Type: SSD
Touchscreen: Yes
Type: Laptop
Brand: HP
Price Range Ex VAT: 1500+
