HP Zbook x2 Core i7-7500U 8GB 256GB SSD 14" Windows 10 Pro
Quicklinx: DWZ0WS00 Mfr#: 2ZB84EA#ABU
  • Core i7
  • IEEE 802.11n
Introducing HP's most powerful detachable PC. With remarkable performance and versatility to push your favorite Adobe applications to the limit, no PC is better suited to turn your vision into reality.
  • Windows 10 Pro for Workstations
    Be productive in any situation. Windows 10 Pro for Workstations and powerful security, collaboration, and connectivity features from HP help you power through your day on the HP ZBook x2.
  • HP DreamColor Display
    Immerse yourself in 1 billion colors on a stunning, 4K, multi-touch display. Work in any lighting with the anti-glare touchscreen - HP's most advanced detachable PC display.
  • HP Quick Keys for short deadlines
    Work quickly and comfortably with 18 equivalent shortcuts at your fingertips, customized for all your favorite Adobe applications.
  • Bluetooth, full-performance detachable keyboard
    The full-sized keyboard is Bluetooth -enabled to stay active when detached, so you have access to shortcut key combinations when working in appications like Adobe Photoshop .
  • Sleek and Portable Design
    Experience the intersection of mobility & performance in a fully-machined, aluminum and die-cast magnesium body starting at just 3.59 pounds and 14.6 mm thin when in tablet mode.
  • NVIDIA Quadro 3D Graphics
    Professional graphics performance that delivers real-time visualization of multi-layered artwork and creative projects.
HP ZBook x2 G4 Detachable Workstation - 14" - Core i7 7500U - 8 GB RAM - 256 GB SSD - UK
Tablet - with Bluetooth keyboard
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (7th Gen) 7500U / 2.7 GHz (3.5 GHz) / 4 MB Cache
8 GB DDR4 (2 x 4 GB)
Storage
256 GB SSD - NVMe, TLC
Display
14" LED backlight touchscreen 3840 x 2160 / Ultra HD 4K
Graphics
NVIDIA Quadro M620 / Intel HD Graphics 620
Video Memory
2 GB GDDR5 SDRAM
Input Device
Detachable keyboard
Keyboard
Keyboard Backlight
802.11a/b/g/n/ac, NFC, Bluetooth 4.2
4-cell - up to 10 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
Dimensions (WxDxH) - tablet
36.45 cm x 22.7 cm x 1.46 cm
1.65 kg
Limited warranty - parts and labour - 3 years
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
Cache
L3 - 4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (2 x 4 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2133 MHz
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), triple-level cell (TLC)
RAID Level
RAID 0, RAID 1
Display
14" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
3840 x 2160 (Ultra HD 4K)
Widescreen
Image Brightness
300 cd/m²
Colour Support
1 billion colours
High Bit Rate 2 (HBR2), Ultra HD 4K ultra wide-viewing angle (UWVA) anti-glare DreamColor
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Video System Features
NVIDIA Optimus, Shader Model 5.0
Sound
Stereo speakers, microphone
Codec
Conexant CX7700
High Definition Audio
Audio Features
Bang & Olufsen Audio, Intel Smart Sound
Input
Detachable keyboard
Keyboard Backlight
Keyboard Layout
Volume control, ClickPad with gesture support, brightness adjustment, on/off touch, kickstand, HP Quick Key
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Miracast
IEEE 802.11, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
4-cell lithium polymer
70 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
90 Watt, 19.5 V
Connections & Expansion
USB 3.0 (charging) , 2 x USB-C 3.1 (supports Thunderbolt 3, DisplayPort 1.2, VGA, HDMI) (Power Delivery) , Headphone/microphone combo jack , HDMI
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Password Manager, Windows Defender, Device Access Manager, HP Velocity, HP PageLift, HP Security Manager, HP BIOS Configuration Utility (free download), HP Credential Manager, HP Client Catalogue (free download), HP Driver Packs, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP MIK for Microsoft SCCM (free download), HP Client Security Suite Gen3, Native Miracast, HP JetAdvantage, HP Workwise (free download), HP Management Integration Kit for Microsoft System Center Configuration Manager (free download), Adobe Creative Cloud Desktop Manager
Security
Power-on password, Intel Anti-Theft Technology (iAT), HP SpareKey, One-Step Logon, Setup Password, Automatic DriveLock, HP Drive Encryption, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, MST (multi-stream transport), Master Boot Record Security, Secure Erase
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion sensor
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, KCC, A-Tick, ICES
Localization
1.65 kg
Dimensions (WxDxH) / Weight Details
36.45 cm x 22.7 cm x 1.46 cm / 1.65 kg - tablet , 36.45 cm x 22.7 cm x 2.03 cm / 2.17 kg - tablet with keyboard
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (8)
Get more from your purchase from one of our essential accessories
DWZ0 HP 90W Smart AC Adapter In Stock £22.69
DWZ0 HP 65W Smart AC Adapter In Stock £18.54
DWZ0 HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack In Stock £13.44
DWZ0 HP Dual Head Keyed Cable Lock In Stock £43.00
DWZ0 HP USB-C mini Dock - Docking Station - USB-C - VGA, HDMI - GigE In Stock £33.61
DWZ0 HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £147.06
DWZ0 HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £206.71
DWZ0 HP Travel Hub G2 Port replicator USB-C VGA, HDMI for Chromebook In Stock £41.06
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
DWZ0 HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site In Stock £123.80
Other bundles (10)
DWZ0 HPE DisplayPort to HDMI Adapter In Stock £13.44
DWZ0 HPE HDMI to DVI Adapter In Stock £9.89
DWZ0 HPE HP DisplayPort to DVI Adapter In Stock £17.23
DWZ0 HP USB-C To VGA Adapter In Stock £22.68
DWZ0 HP USB Travel Mouse In Stock £10.14
DWZ0 HP X4000b Bluetooth Mouse In Stock £28.71
DWZ0 HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
DWZ0 HP Premium Wireless Mouse In Stock £38.00
DWZ0 HP USB-C to DisplayPort Adapter In Stock £23.53
DWZ0 HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor In Stock £144.44
