HP ZBook Studio x360 G5 Core i7-8750H 16GB 256GB SSD 15.6" Touch Windows 10 Professional 64-bit
Quicklinx: F70FWS00 Mfr#: 6KP03ET#ABU
Display Size: 15.6in
Processor Model: I7-8750H
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB
Hard Drive Capacity: 256GB
  • Core i7
  • IEEE 802.11n
£1,252.57 ex VAT
£1,503.08 inc VAT
Reimagine your creative process with a versatile laptop that gives you the latest convertible design you'll want with the pro-grade performance you need. Showcase your work like never before with five unique modes.
  • 360-degree pro performance
    Finally, a convertible laptop designed to tackle large files and run multiple apps with speed and responsiveness. Seamlessly edit and render high-res images without delay, with NVIDIA Quadro P2000 graphics, 64 GB memory and Intel Core i9 processors.
  • Precision-crafted versatility
    With our innovative 360-degree hinge, you'll get the comfort of a laptop, the convenience of a tablet and the luxury of additional modes to help you showcase your work.
  • Pixel-perfect tools
    Achieve remarkable inking precision with 4096 levels of pressure sensitivity and tilt with the Wacom AES pen. And with the HP DreamColor matte touchscreen, you'll experience one billion vibrant colors on HP's brightest 4K UHD laptop display.
HP ZBook Studio x360 G5 Mobile Workstation - 15.6" - Core i7 8750H - 16 GB RAM - 256 GB SSD - UK
Notebook - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
16 GB DDR4 (2 x 8 GB)
Storage
256 GB SSD SED, TLC
Optical Drive
No optical drive
Display
15.6" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 630
Input Device
ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0
4-cell - up to 18.5 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
36 cm x 25.4 cm x 1.87 cm
2.22 kg
Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
Cache
9 MB
64-bit Computing
Chipset
Mobile Intel CM246
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (2 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
256 GB SSD - (M.2 2280) SATA 6Gb/s - Self-Encrypting Drive, triple-level cell (TLC)
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
400 cd/m²
Ambient light sensor, 100% sRGB colour gamut, Panel Self Refresh (PSR), Corning Gorilla glass 4, Full HD eDP anti-glare
Keyboard Name
HP Collaboration
Audio & Video
Graphics Processor
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Low light enhancement
Sound
Stereo speakers, dual array microphone
High Definition Audio
Audio Features
Bang & Olufsen Audio, HP Clear Sound Amp
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch clickpad, gesture function
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560 - PCI Express Mini Card (M.2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
4-cell lithium polymer
64 Wh
Run Time
Up to 18.5 hours
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
USB 3.0 (charging) , USB 3.0 , HDMI , 2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort 1.3 , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Security
Power-on password, One-Step Logon, Setup Password, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, BIOS Update via Network, HP Sure Click
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, FCC
Localization
2.22 kg
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP ZBook Studio x360 G5 Core i7-8750H 16GB 256GB SSD 15.6 Bundle deal on HP ZBook Studio x360 G5 Core i7-8750H 16GB 256GB SSD 15.6" Touch Windows 10 Professional 64-bit
£1,432.15
saving £2.42
£1,351.74
Optical Storage: None
Graphics: Intel UHD Graphics 630
Hard Drive Type: SSD
Brand: HP
Price Range Ex VAT: 1000 - 1500
