Be ready when inspiration strikes. Packed with professional performance in an incredibly sleek PC that comfortably fits in your bag, the ZBook Studio is engineered to get you in the zone and help you stay focused. Now you can build complex assemblies, render in real time or visualize data-from anywhere.
Windows 11
Work anywhere without compromising on performance or security with Windows 11 powered by HP's collaboration and connectivity technology. -
Intel Core i7 processor
Run several CPU–heavy programs simultaneously without sacrificing performance with an Intel Core i7 processor. -
HP Z Turbo Drive High-speed Storage
Work without limits in any location with local PCIe storage that's up to 6x faster than SATA SSD, and up to 21x faster than traditional HDD storage. -
HP Fast Charge
Ultra-fast recharge takes you from zero to 50% charge in just 30 minutes. -
Spill-resistant Keyboard
Accidents happen - which is why we designed our keyboard with a drain hole, so minor spills flow out the bottom for easy cleanup. -
Industry-leading security features
Advanced security features come standard. System safeguards like HP Sure Start – the industry's first self-healing BIOS – mean your device is locked down tight, so your data and identity are too.
- HP ZBook Studio G9 Mobile Workstation - 16" - Intel Core i7 - 12700H - 32 GB RAM - 512 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit (downgrade from Windows 11 Pro) + Windows 11 Pro Licence - English
- Processor
- Intel Core i7 (12th Gen) - 12700H / 2.3 GHz, up to 4.7 GHz / 24 MB Cache
- Memory
- 32 GB DDR5 (2 x 16 GB)
- Storage
- 512 GB SSD - NVMe, TLC
- Display
- 16" WLED 1920 x 1200 / WUXGA @ 60 Hz - 142 ppi
- Graphics
- NVIDIA RTX A1000 / Intel Iris Xe Graphics
- Video Memory
- 4 GB GDDR6 SDRAM
- Input Device
- Keyboard, ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 5.2, 802.11a/b/g/n/ac/ax (Wi-Fi 6E)
- Battery
- 6-cell - up to 12.8 hours
- Tile module, HP Tamper Lock
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- 35.6 cm x 24.2 cm x 1.9 cm
- 1.78 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition (available through downgrade rights from Windows 11 Pro) + Windows 11 Pro Licence - English
Processor / Chipset
- CPU
- Intel Core i7 (12th Gen) 12700H / 2.3 GHz
- Max Turbo Speed
- 4.7 GHz
- Number of Cores
- 14-core
- Cache
- L3 - 24 MB
- Intel Turbo Boost Technology
- RAM
- 32 GB (2 x 16 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR5 SDRAM
- Speed
- 4800 MHz
- Rated Speed
- 4800 MHz
- Form Factor
- SO-DIMM 262-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe 4.0 x4 - NVM Express (NVMe), triple-level cell (TLC)
Display
- 16" - IPS
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1200 (WUXGA)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 142
- Image Aspect Ratio
- 16:10
- Image Brightness
- 400 cd/m²
- Colour Gamut
- 100% sRGB
- Low Blue Light technology, Low Power, narrow bezel bent, WUXGA ultra wide-viewing angle (UWVA) anti-glare eDP +PSR2
- Keyboard Name
- HP Premium Quiet Keyboard
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 4 GB GDDR6 SDRAM
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Camera Features
- IR camera, Windows Hello
- Sound
- Four speakers, HP World Facing Microphone / dual-array digital microphone
- Codec
- Realtek ALC3315
- High Definition Audio
- Audio Features
- Output: Bang & Olufsen Audio, 200 Hz bass roll off
Input
- Keyboard Layout
- UK
- Volume control, multi-touch clickpad, gesture function, glass clickpad, image sensor, spill-resistant
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Wi-Fi 6E AX 211 - PCI Express Mini Card (M.2)
- Miracast, dual stream (2x2)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.11i, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax, Bluetooth 5.2, Wi-Fi CERTIFIED 6E
- Technology
- 6-cell lithium polymer
- Capacity
- 86 Wh
- Run Time
- Up to 12.8 hours
AC Adapter
- Input
- AC 115/230 V (50/60 Hz)
- Output
- 150 Watt, 19.5 V, 16 A
Connections & Expansion
- Interfaces Details
- USB 3.1 Gen 1 (charging) , Headphone/microphone combo jack , 2 x USB-C 3.2 Gen 2 (supports Thunderbolt 4, DisplayPort 1.4 Alt Mode) (Power Delivery, Sleep & Charge) , USB-C 3.2 Gen 2 (supports DisplayPort 1.4 Alt Mode) (Power Delivery)
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC, microSDUC)
Software
- Software Included
- HP Support Assistant, HP Power Manager, HP Hotkey Support, HP Performance Advisor, HP Secure Erase, HP Client Catalogue (free download), HP Client Security Manager, HP Device Access Manager, HP PC Hardware Diagnostics, HP MAC Address Manager, HP Manageability & Integration Kit (free download), HP Notifications, HP Privacy Settings, HP Cloud Recovery, HP QuickDrop, HP Client Management Script Library (free download), HP BIOSphere Gen6, HP Wake on WLAN, myHP, Touchpoint Customiser for Commercial, HP Noise Cancellation Software, HP Image Assistant Gen5 (free download), Tile, HP Easy Clean, Adobe (1 month trial), HP Smart Support, Data Science Stack, HP Connect for Microsoft Endpoint Manager, HP Patch Assistant (free download), HP Z Light Space, HP Driver Packs (free download)
- Integrated Options
- Security
- Automatic DriveLock, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, Master Boot Record Security, BIOS Update via Network, Secured-core PC enabled
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- HP 150 Watt Smart Slim AC Adapter
- CSA, UL, VCCI, BSMI, SABS, CCC, FCC, RoHS, KCC, A-Tick, ICES, EAC, CIT, low halogen, RED, MIL-STD-810H, BNCI
- Localization
- 1.78 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (4)
Get more from your purchase from one of our essential accessories
HP Prelude Top Load 15.6" Notebook Carrying Case | In Stock | £10.25 |
HP Thunderbolt Dock G4 - USB-C / Thunderbolt 4 - HDMI, 2 x DP, Thunderbolt, USB-C - 1GbE, 2.5GbE | In Stock | £549.09 |
HP Nano - Security Cable Lock | In Stock | £15.75 |
HP Renew Business - Notebook carrying shoulder bag - 17.3" | In Stock | £18.92 |
Warranty Packs (2)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack NBD Hardware Support for Travelers | In Stock | £128.29 |
HP Care Pack Next Business Day Active Care Service - extended service agreement - 3 years - on-site | In Stock | £135.14 |
Other bundles (54)
HP USB-C To VGA Adapter | In Stock | £23.07 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £47.44 |
HP USB G2 Stereo Headset | In Stock | £20.21 |
HP 128 Wired Mouse | In Stock | £8.48 |
HP 455 Programmable Keyboard - Wireless - UK | In Stock | £26.44 |
Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter | In Stock | £208.06 |
Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A | In Stock | £208.06 |
Poly DA75 Sound Card | In Stock | £27.38 |
Poly Voyager 4320 UC V4320-M C USB-A WW | In Stock | £110.61 |
Poly Voyager 4320 UC V4320 C USB-C WW | In Stock | £106.60 |
Poly DA85-M Sound Card | In Stock | £44.59 |
Poly EncorePro HW520 Stereo Headset (Noise Cancelling) | In Stock | £65.27 |
Poly DA85 Headset Cable - USB-C to Quick Disconnect | In Stock | £43.34 |
Poly Voyager 4320 UC V4320-M C USB-A CS WW | In Stock | £108.73 |
Poly Voyager 4320 UC V4320-M C USB-C WW | In Stock | £110.85 |
Poly Voyager 4320 UC V4320 C USB-A CS WW | In Stock | £119.64 |
Poly Voyager 4310 UC V4310-M C USB-A WW | In Stock | £98.17 |
Poly Voyager 4320 UC V4320-M C USB-C CS WW | In Stock | £115.93 |
Poly Voyager 4310 UC V4310-M C USB-A CS WW | In Stock | £110.61 |
Poly Voyager 4320 UC V4320 C USB-A WW | In Stock | £106.60 |
Poly Voyager 4310 UC V4310 C USB-A WW | In Stock | £98.17 |
Poly Voyager 4310 UC V4310 C USB-A CS WW | In Stock | £111.00 |
Poly Sync 10 SY10-M USB-A/C WW | In Stock | £55.19 |
Poly EncorePro 525 USB EP525 USB-A Headset | In Stock | £87.21 |
Poly Voyager Focus 2 UC-M USB-C Headset with Stand | In Stock | £141.12 |
Poly Sync 40 SY40-M WW | In Stock | £127.56 |
Poly Blackwire 8225 Stereo Microsoft Teams Certified USB-C | In Stock | £109.27 |
Poly Blackwire 3320 on-ear - wired - USB-C - black - Certified for Microsoft Teams, UC certified | In Stock | £30.35 |
Poly Poly Blackwire 3320 Stereo USB-C/A Adapter | In Stock | £30.35 |
Poly Blackwire 5220 Stereo USB-C Headset + 3.5mm Plug + USB-C | In Stock | £67.04 |
Poly Blackwire 3315 headset - on-ear - wired - 3.5 mm jack, USB-C - black - UC certified | In Stock | £45.04 |
Poly Wireless Headset System Base for Bluetooth headset - for Poly Voyager | In Stock | £89.69 |
HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £164.32 |
HP OMEN 24" Full HD 165Hz Gaming Monitor | In Stock | £121.33 |
HP OMEN 27" Full HD 165Hz Gaming Monitor | In Stock | £145.60 |
Poly Blackwire 3210 headset - on-ear - wired - USB-C - black | In Stock | £25.87 |
Poly Blackwire 5210 Monaural USB-C Headset +3.5mm Plug +USB-C/A Adapter | In Stock | £61.00 |
Poly Blackwire 3310 headset - on-ear - wired - USB-A - black | In Stock | £25.49 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £25.93 |
Poly Blackwire 3220 headset - on-ear - wired - USB-C - black | In Stock | £25.27 |
Poly Blackwire 3310 Monaural USB-C Headset + USB-C/A Adapter | In Stock | £24.80 |
Poly EncorePro 515-M headset - on-ear - wired - USB-A - black | In Stock | £77.77 |
HP P34hc G4 P-Series 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor | In Stock | £491.31 |
HP 732pk Series 7 Pro 32" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor | In Stock | £615.80 |
HP E24mv G4 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Conferencing Monitor | In Stock | £165.42 |
Poly Voyager 4310 Mono UC V4310 USB-C Microsoft Teams | In Stock | £108.17 |
Poly EncorePro HW520D - headset - Quick Disconnect | In Stock | £105.92 |
Poly HP Poly Blackwire 3325 - headset - 3.5 mm jack, USB-C | In Stock | £49.77 |
Poly Blackwire 3215 - headset - 3.5 mm jack, USB-C | In Stock | £41.83 |
Poly Blackwire 5210 - headset - 3.5 mm jack, USB-C | In Stock | £61.00 |
Poly Blackwire 3220 USB-C HS +USB-C/A Headset | In Stock | £26.96 |
Poly Blackwire 5220 USB-C HS +USB-C/A Headset | In Stock | £63.33 |
