HP ZBook Studio G5 x360 i7-8550H 16GB 512GB SSD 15.6" Windows 10 Pro
Quicklinx: DQH5WS00 Mfr#: 2ZC61ET#ABU
Display Size: 15.6in
Processor Model: I7-8850H
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB
Hard Drive Capacity: 512GB
  • Core i7
  • IEEE 802.11n
£2,759.79 ex VAT
£3,311.74 inc VAT
Reimagine your creative process with a versatile laptop that gives you the latest convertible design you'll want with the pro-grade performance you need.
  • 360-degree pro performance
    Finally, a convertible laptop designed to tackle large files and run multiple apps with speed and responsiveness. Seamlessly edit or render high-res images without lag or delay, with NVIDIA Quadro graphics and 6-core Intel Xeon processors.
  • Precision-crafted versatility
    With our innovative 360-degree hinge, you'll get the comfort of a laptop, the convenience of a tablet and the luxury of additional modes to help you showcase your work.
  • Pixel-perfect tools
    Achieve remarkable inking precision with 4000 levels of pressure sensitivity and tilt with the Wacom AES pen. And with the HP DreamColor display, you'll experience one billion vibrant colors on HP's brightest 4K laptop.
HP ZBook Studio x360 G5 Mobile Workstation - 15.6" - Core i7 8850H - 16 GB RAM - 512 GB SSD - QWERTY UK
Notebook - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) 8850H / 2.6 GHz (4.3 GHz) / 9 MB Cache
16 GB DDR4 (2 x 8 GB)
Storage
512 GB - M.2 2280 SSD SED, NVMe + 16 GB SSD cache (M.2) (3D Xpoint (Optane))
Optical Drive
No optical drive
Display
15.6" LED backlight touchscreen 3840 x 2160 / Ultra HD 4K
Graphics
NVIDIA Quadro P1000 / Intel UHD Graphics 630
Video Memory
4 GB GDDR5 SDRAM
Input Device
ClickPad
Keyboard Backlight
802.11a/b/g/n/ac, Bluetooth 5.0
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
36 cm x 25.4 cm x 2.04 cm
2.26 kg
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4.3 GHz
Number of Cores
6-core
Cache
L3 - 9 MB
64-bit Computing
Chipset
Mobile Intel CM246
Platform Technology
Intel vPro Technology
Intel Turbo Boost Technology
RAM
16 GB (2 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2666 MHz - 2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
512 GB SSD - (M.2 2280) PCIe - Self-Encrypting Drive, NVM Express (NVMe)
SSD Cache
16 GB 3D Xpoint (Optane) (M.2)
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
3840 x 2160 (Ultra HD 4K)
Widescreen
Image Brightness
400 cd/m²
Ambient light sensor, Corning Gorilla glass 4, Ultra HD 4K eDP
Keyboard Name
HP Collaboration
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Sound
Stereo speakers, dual array microphone
Audio Features
Bang & Olufsen Audio, HP Clear Sound Amp
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
QWERTY UK
Volume control, multi-gesture touch pad, spill-resistant, ClickPad with gesture support
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560 - PCI Express Mini Card (M.2)
Dual stream (2x2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
4-cell Lithium Ion
Installed Qty
1
64 Wh
AC Adapter
Output
150 Watt, 19.5 V
Connections & Expansion
Slots
2 x M.2 Card
2 x USB-C 3.1/Thunderbolt 3/DisplayPort 1.3 , USB 3.0 (charging) , USB 3.0 , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
HP Remote Graphics Software, HP Performance Advisor, Password Manager, Windows Defender, HP Secure Erase, HP Security Manager, HP Credential Manager, HP Client Catalogue (free download), HP Driver Packs, HP BIOS Config Utility, HP Device Access Manager, HP Noise Cancellation, HP System Software Manager (free download), HP Management Integration Kit for Microsoft System Center Configuration Manager (free download), HP Sure Click, HP BIOSphere Gen4, HP Host Based MAC Address Manager
Security
Power-on password, Intel Active Management Technology (iAMT), One-Step Logon, Setup Password, HP Automatic Drive Lock, HP DriveLock, Measured Boot, Power On Authentication, HP Fast Charge, Pre-boot Authentication, HP Sure Start Gen 4, HP Sure Run, HP Sure Recover, BIOS Update via Network, HP Sure Click
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, FCC, WEEE 2002/96/EC, low halogen, ISO 11469, ISO 1043, RoHS 2011/65/EC
Localization
2.26 kg
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine wave
Shock Tolerance (non-operating)
240 g @ 2 ms half-sine wave
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP ZBook Studio G5 x360 i7-8550H 16GB 512GB SSD 15.6 Bundle deal on HP ZBook Studio G5 x360 i7-8550H 16GB 512GB SSD 15.6" Windows 10 Pro
£2,947.43
saving £8.33
£2,859.55
Optical Storage: None
Graphics: NVIDIA Quadro P1000 / Intel UHD Graphics 630
Hard Drive Type: SSD
Type: Laptop
Brand: HP
Price Range Ex VAT: 1500+
