HP ZBook Studio G5 Intel Core i7-8750H 8GB 256GB SSD 15.6" Windows 10 Professional 64-bit
Quicklinx: F70CWS00 Mfr#: 6KP01ET#ABU
Display Size: 15.6in
Processor Model: I7-8750H
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i7
  • IEEE 802.11n
£1,782.29 ex VAT
£2,138.74 inc VAT
Get the perfect blend of ultra-slim design & pro-grade performance in the new HP ZBook Studio. Remove limitations from your creative workflow with fast editing and rendering, and bring your ideas to life on HP's brightest 4K UHD laptop display.
  • HP's brightest 4K UHD laptop display
    See your work in one billion vibrant colors on the HP DreamColor display with 600 nits of brightness. Master color-critical work with 100% Adobe RGB coverage that helps maintain perfect color every single time.
  • More powerful than ever before
    Get ultra fast performance with the latest Intel Core i9 processors and 64 GB memory. Render photorealistic images with certified NVIDIA Quadro P2000 graphics - optimized for stability and peak performance with professional software apps.
  • HP's most secure mobile workstation
    Protect your work with industry-leading security features. A touch of a button activates HP Sure View privacy screen to protect against visual hacking and RAID 1 maintains a backup copy of all your files in case you ever need it.
HP ZBook Studio G5 Mobile Workstation - 15.6" - Core i7 8750H - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD NVMe, TLC
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro P1000 / Intel UHD Graphics 630
Video Memory
4 GB GDDR5 SDRAM
Input Device
ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0
6-cell
Ambient light sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip
36 cm x 25.4 cm x 1.74 cm
2 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
Cache
9 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
DDR4 SDRAM
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe), triple-level cell (TLC)
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
400 cd/m²
Full HD eDP anti-glare
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Camera
Yes - HD
Video Resolutions
720p
Sound
Stereo speakers, dual array microphone
High Definition Audio
Audio Features
Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, gesture function
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wireless-AC 9560
IEEE 802.1x, IEEE 802.11i
6-cell lithium polymer
95.6 Wh
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort 1.3 , USB 3.0 (charging) , USB 3.0 , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SDHC Card, SDXC Card, SDXC UHS-II Card)
Integrated Options
Security
Power-on password, One-Step Logon, Setup Password, Automatic DriveLock, HP DriveLock, Measured Boot, Power On Authentication, Pre-boot Authentication, Secure Erase, HP Sure Start Gen 4, HP Sure Run, HP Sure Recover, BIOS Update via Network, HP Sure Click
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
Localization
2 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP ZBook Studio G5 Intel Core i7-8750H 8GB 256GB SSD 15.6 Bundle deal on HP ZBook Studio G5 Intel Core i7-8750H 8GB 256GB SSD 15.6" Windows 10 Professional 64-bit
£1,881.46
Optical Storage: None
Graphics: NVIDIA Quadro P1000 / Intel UHD Graphics 630
Hard Drive Type: SSD
Brand: HP
Price Range Ex VAT: 1500+
