HP ZBook Studio G3 Mobile Workstation Intel Core i7-6700HQ 8GB 256GB SSD 15.6" Windows 10 Pro
Quicklinx: C4SVWS00 Mfr#: T7W01ET#ABU
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
Conquer the workday with the perfect combination of brains and beauty. The iconic 39,6 cm (15.6") diagonal HP ZBook Studio is HP's thinnest, lightest, and most attractive full performance mobile workstation.
  • Choose the OS for you
    Support your unique user needs with a choice of Windows 10 Pro or Windows 7 operating systems.
  • Innovate anywhere
    The HP ZBook Studio Mobile Workstation delivers sleek style, impressive performance, and long battery life.
  • New powerful processors
    Get powerful performance from 6th generation Intel Core and Intel Xeon processor options.
  • Professional-grade graphics
    Take productivity up a notch with the ability to do more thanks to NVIDIA Quadro mid-range professional graphics.
  • Work smarter
    Take on challenging tasks with confidence with up to 32 GB DDR4 with optional ECC memory for no compromise capacity, performance and reliability.
  • Ultra-fast storage
    Reduce boot up, calculation, and response times by revolutionizing how your HP ZBook handles large files with optional dual 1 TB HP Z Turbo Drive G2 storage for a remarkably fast and innovative solution.
HP ZBook Studio G3 Mobile Workstation - 15.6" - Intel Core i7 - 6700HQ - 8 GB RAM - 256 GB SSD - UK
Mobile workstation
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD - HP Z Turbo Drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro M1000M / Intel HD Graphics 530
Video Memory
4 GB GDDR5 SDRAM
Input Device
Keyboard, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 1.2) Security Chip
Space Silver
37.5 cm x 25.5 cm x 1.8 cm
2 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - parts and labour - 3 years
Mobile workstation
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
CPU
Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Chipset
Mobile Intel CM236 Express
Enhanced SpeedStep technology, Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe - HP Z Turbo Drive
RAID Level
RAID 0, RAID 1
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Multi-Stream transport (MST), Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Video System Features
NVIDIA Optimus
Camera
Yes - 1280 x 720
Camera Features
720p HD movie recording, low light enhancement
Sound
Stereo speakers, two microphones
Codec
CX7501
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, ClickPad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Remote Management Protocol
SNMP 2
Miracast, Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
4-cell Lithium Ion
64 Wh
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
Interfaces Details
LAN , 3 x USB 3.0 , 2 x Thunderbolt 3 , Headphone/microphone combo jack , HDMI
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC UHS-II Card)
Software
Software Included
Cyberlink PowerDVD, HP Recovery Disc Creator, Skype, LANDesk Management Suite, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP ePrint, HP Hotkey Support, HP Performance Advisor, CyberLink YouCam BE, HP Systems Software Manager, Foxit PhantomPDF Express, HP Spare Key, HP Registration, HP Velocity, HP Security Manager, HP BIOSphere, HP GPS and Location, HP Client Catalog, HP Client Catalogue (free download), HP Driver Packs, HP BIOS Config Utility, HP CIK for Microsoft SCCM, HP 3D DriveGuard, HP Noise Reduction Software
Space Silver
Case Material
Magnesium-aluminum alloy
Security
HP 3D DriveGuard, HP DuraKeys, HP SpareKey, HP BIOS Protection, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port, Pre-boot Authentication, HP Sure Start with Dynamic Protection
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, FCC, RoHS, MIL-STD 810G, WEEE, Common Criteria EAL4+
Localization
2 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
