Product
HP ZBook Studio G3 Mobile Workstation 15.6" Intel Core i7 6700HQ 8GB RAM 256GB SSD Windows 7 Pro
Quicklinx: CKJNWS00 Mfr#: T7W01EA#ABU
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
Conquer the workday with the perfect combination of brains and beauty. The iconic 39,6 cm (15.6") diagonal HP ZBook Studio is HP's thinnest, lightest, and most attractive full performance mobile workstation.
Brilliant inside and out
Make a bold statement with innovative style and performance. Starting at just 1.99 kg (4.4 lbs) and 18mm thin, the HP ZBook Studio is a meticulously-designed performance machine.
Create your ideal workstation
Get looks and performance with Intel Xeon processor options, dual 1 TB HP Z Turbo Drive G2 for up to 2 TB of total storage, up to 32 GB ECC memory, dual Thunderbolt 3, and optional HP DreamColor UHD or FHD touch displays.
Defined by HP Z DNA
Work confidently with HP mobile workstations designed around 30 years of HP Z DNA with extensive ISV certification. It's reliable, designed to pass MIL-STD 810G testing, and endure 120K hours in HP's Total Test Process.
  • Brilliant inside and out
  • Create your ideal workstation
  • Defined by HP Z DNA
HP ZBook Studio G3 Mobile Workstation - 15.6" - Core i7 6700HQ - 8 GB RAM - 256 GB SSD - UK
Ultrabook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz (3.5 GHz) / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB - M.2 SSD HP Z Turbo Drive
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro M1000M / Intel HD Graphics 530
Video Memory
4 GB GDDR5 SDRAM
Input Device
ClickPad
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader
Space Silver
37.5 cm x 25.5 cm x 1.8 cm
2 kg
Environmental Standards
ENERGY STAR Qualified
Ultrabook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Chipset
Mobile Intel CM236 Express
Enhanced SpeedStep technology, Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2133 MHz / PC4-17000 - 2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2) PCIe - HP Z Turbo Drive
RAID Level
RAID 0, RAID 1
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Multi-Stream transport (MST), Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Video System Features
NVIDIA Optimus
Camera
Yes - 1280 x 720
Camera Features
720p HD movie recording, low light enhancement
Sound
Stereo speakers, two microphones
Codec
CX7501
Audio Features
Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, ClickPad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Remote Management Protocol
SNMP 2
Miracast, Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
4-cell Lithium Ion
64 Wh
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
2 x Thunderbolt 3 , HDMI , Headphone/microphone combo jack , LAN , 2 x USB 3.0
Memory Card Reader
Yes (SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, HP Performance Advisor, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, Password Manager, Windows Defender, HP Client Security, HP Mobile Connect, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP Security Manager, HP BIOSphere, HP GPS and Location, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Credential Manager, HP Client Catalogue (free download), Absolute Persistence, LANDesk Management Suite (free download), HP CIK for Microsoft SCCM (free download), HP Noise Reduction Software, HP Image Assistant
Space Silver
Case Material
Magnesium-aluminum alloy
Security
HP 3D DriveGuard, HP DuraKeys, HP SpareKey, HP BIOS Protection, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port, Pre-boot Authentication, HP Sure Start with Dynamic Protection
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, FCC, RoHS, MIL-STD 810G, WEEE, Common Criteria EAL4+
Localization
2 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
