Conquer the workday with the perfect combination of brains and beauty. The iconic 39,6 cm (15.6") diagonal HP ZBook Studio is HP's thinnest, lightest, and most attractive full performance mobile workstation.
Brilliant inside and out
Make a bold statement with innovative style and performance. Starting at just 1.99 kg (4.4 lbs) and 18mm thin, the HP ZBook Studio is a meticulously-designed performance machine. -
Create your ideal workstation
Get looks and performance with Intel Xeon processor options, dual 1 TB HP Z Turbo Drive G2 for up to 2 TB of total storage, up to 32 GB ECC memory, dual Thunderbolt 3, and optional HP DreamColor UHD or FHD touch displays. -
Defined by HP Z DNA
Work confidently with HP mobile workstations designed around 30 years of HP Z DNA with extensive ISV certification. It's reliable, designed to pass MIL-STD 810G testing, and endure 120K hours in HP's Total Test Process.
- HP ZBook Studio G3 Mobile Workstation - 15.6" - Core i7 6700HQ - 8 GB RAM - 128 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Processor
- Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz (3.5 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 128 GB SSD TLC
- Optical Drive
- No optical drive
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 530
- Input Device
- ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Space Silver
- 37.5 cm x 25.5 cm x 1.8 cm
- 2 kg
- Localisation
- Limited warranty - parts and labour - 3 years
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- L3 - 6 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM236 Express
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 128 GB SSD - (M.2 2280) SATA 6Gb/s - triple-level cell (TLC)
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 300 cd/m²
- Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR, 141 ppi
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- Low light enhancement
- Sound
- Stereo speakers, dual array microphone
- High Definition Audio
- Audio Features
- Bang & Olufsen Audio
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Volume control, spill-resistant, ClickPad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
- Remote Management Protocol
- SNMP 2
- Miracast, Wake-on-LAN (WOL)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
- Technology
- 4-cell Lithium Ion
- Capacity
- 64 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 150 Watt, 19.5 V
Connections & Expansion
- 2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort , HDMI , Headphone/microphone combo jack , LAN , 2 x USB 3.0 , USB 3.1 (charging)
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
- Space Silver
- Security
- HP 3D DriveGuard, HP DuraKeys, HP SpareKey, HP BIOS Protection, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, Pre-boot Authentication, HP Sure Start with Dynamic Protection
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
- Localization
- 2 kg
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Software applications
Bundle includes:
Microsoft Office Home & Business 2019 Box Pack (Medialess, 1 PC, One Time Purchase) worth £191.49 | in stock |
£2,005.23
saving £8.33
saving £8.33
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£1,921.24
