HP ZBook studio G3 Core i7-6700HQ 8GB 128GB SSD 15.6" Windows 10 Pro
Quicklinx: DPYNWS00 Mfr#: 1RQ45EA#ABU
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
Conquer the workday with the perfect combination of brains and beauty. The iconic 39,6 cm (15.6") diagonal HP ZBook Studio is HP's thinnest, lightest, and most attractive full performance mobile workstation.
  • Choose the OS for you
    Support your unique user needs with a choice of Windows 10 Pro or Windows 7 operating systems.
  • Innovate anywhere
    The HP ZBook Studio Mobile Workstation delivers sleek style, impressive performance, and long battery life.
  • New powerful processors
    Get powerful performance from 6th generation Intel Core and Intel Xeon processor options.
  • Professional-grade graphics
    Take productivity up a notch with the ability to do more thanks to NVIDIA Quadro mid-range professional graphics.
  • Work smarter
    Take on challenging tasks with confidence with up to 32 GB DDR4 with optional ECC memory for no compromise capacity, performance and reliability.
  • Ultra-fast storage
    Reduce boot up, calculation, and response times by revolutionizing how your HP ZBook handles large files with optional dual 1 TB HP Z Turbo Drive G2 storage for a remarkably fast and innovative solution.
HP ZBook Studio G3 Mobile Workstation - 15.6" - Intel Core i7 - 6700HQ - 8 GB RAM - 128 GB SSD - UK
Mobile workstation
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
128 GB SSD - TLC
Display
15.6" LED backlight 1920 x 1080 / Full HD - 141 ppi
Graphics
Intel HD Graphics 530
Input Device
Keyboard, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 1.2) Security Chip
Space Silver
37.5 cm x 25.5 cm x 1.8 cm
2 kg
Limited warranty - parts and labour - 3 years
Mobile workstation
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
CPU
Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
L3 - 6 MB
64-bit Computing
Chipset
Mobile Intel CM236 Express
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
128 GB SSD M.2 2280 SATA 6Gb/s - triple-level cell (TLC)
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Pixel Density (ppi)
141
Image Brightness
300 cd/m²
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR
Audio & Video
Graphics Processor
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Low light enhancement
Sound
Stereo speakers, dual array microphone
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, ClickPad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Remote Management Protocol
SNMP 2
Miracast, Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
4-cell Lithium Ion
64 Wh
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
Interfaces Details
2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) , HDMI , Headphone/microphone combo jack , LAN , 2 x USB 3.0 , USB 3.1 (charging)
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Space Silver
Security
HP 3D DriveGuard, HP DuraKeys, HP SpareKey, HP BIOS Protection, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, Pre-boot Authentication, HP Sure Start with Dynamic Protection
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
Localization
2 kg
Sustainability Information
TCO Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
DPYN HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack In Stock £13.44
DPYN HP Dual Head Keyed Cable Lock In Stock £43.00
Other bundles (6)
DPYN HPE HDMI to DVI Adapter In Stock £9.89
DPYN HP USB-C To VGA Adapter In Stock £22.68
DPYN HP USB Travel Mouse In Stock £9.99
DPYN HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
DPYN HP Premium Wireless Mouse In Stock £38.00
DPYN HP USB-C to DisplayPort Adapter In Stock £23.53
