HP ZBook G4 Core i5-7440 8GB 500GB SSD 15.6" Windows 10 Pro
Quicklinx: DPYLWS00 Mfr#: 1JB31AW#ABU
Display Size: 15.6in
Processor Model: I5-7440HQ
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 500GB
  • Core i5
  • IEEE 802.11n
£1,875.43 ex VAT
£2,250.51 inc VAT
We built desktop workstation power, performance and expandability into a device designed for the road. Made for mobile creative and design professionals with the most demanding projects, where compromise is simply not an option.
  • Discover gravity defying performance
    Made for the most demanding workloads, the HP ZBook 15 is used by NASA to help push the boundaries of science and discovery on the International Space Station. Imagine what it could do for you.
  • Extreme power
    Designed for your most demanding workloads, our HP ZBook 15 is engineered with the latest Intel Xeon processors, NVIDIA Quadro or AMD Radeon Pro graphics, up to 3 TB of storage and dual Thunderbolt 3 ports.
  • No compromise reliability
    Confidently take on your workday with our durable & reliable HP ZBook 15. With a 3-year onsite limited warranty, 120,000 hours of testing, and 30 years of HP Z DNA this is where the fusion of innovation, performance & reliability meet.
HP ZBook 15 G4 Mobile Workstation - 15.6" - Core i5 7440HQ - 8 GB RAM - 500 GB Hybrid Drive - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (7th Gen) 7440HQ / 2.8 GHz (3.8 GHz) / 6 MB Cache
8 GB DDR4 (2 x 4 GB)
Storage
500 GB Hybrid Drive (8 GB flash) / 5400 rpm
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro M1200 / Intel HD Graphics 630
Video Memory
4 GB GDDR5 SDRAM
Input Device
Pointing stick
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
9-cell - up to 17.43 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
Space Silver
38.6 cm x 26.4 cm x 2.6 cm
2.6 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
Cache
L3 - 6 MB
64-bit Computing
Chipset
Mobile Intel CM238 Express
Intel Turbo Boost Technology 2.0
RAM
8 GB (2 x 4 GB)
Max RAM Supported
64 GB
DDR4 SDRAM - non-ECC
Speed
2400 MHz / PC4-19200
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
4
Empty Slots
2
Storage
Main Storage
500 GB Hybrid Drive SATA 6Gb/s (8 GB flash) / 5400 rpm
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
300 cd/m²
Full HD standard-viewing angle (SVA) eDP anti-glare +PSR, 141 ppi
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Video System Features
NVIDIA Optimus, Shader Model 5.0
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Low light enhancement
Sound
Stereo speakers, two microphones
Codec
CX7501
High Definition Audio
Audio Features
Bang & Olufsen Audio
Input
Keyboard, touchpad, pointing stick
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
9-cell lithium polymer
90 Wh
Run Time
Up to 17.43 hours
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
2 x Thunderbolt 3 , 2 x USB 3.0 , Headphone/microphone combo jack , HDMI , VGA , LAN , USB 3.0 (charging)
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
Skype, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Windows Defender, HP Velocity, HP Secure Erase, HP Security Manager, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP Device Access Manager, HP 3D DriveGuard 6, HP Image Assistant, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP BIOSphere Gen3, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP System Software Manager (free download)
Space Silver
Security
HP 3D DriveGuard, HP DuraKeys, soft-touch surface, HP BIOS Protection, Automatic DriveLock, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3, Master Boot Record Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
Localization
2.6 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP ZBook G4 Core i5-7440 8GB 500GB SSD 15.6 Bundle deal on HP ZBook G4 Core i5-7440 8GB 500GB SSD 15.6" Windows 10 Pro
£2,058.44
saving £8.33
£1,974.60
Optical Storage: None
Graphics: NVIDIA Quadro M1200 / Intel HD Graphics 630
Hard Drive Type: Hybrid Drive
Type: Laptop
Brand: HP
Price Range Ex VAT: 1500+
