Creativity knows no limits. Showcase your best work in the office or on the go. With the new HP ZBook 17 workstation, take advantage of HP's most powerful processing and graphics, consistent color throughout your workflow, simple scalability, and the blazing-fast connectivity your team needs to perform and collaborate at the speed of creativity.
Innovative, sleek design
Proudly display your work on a large, 43,9 cm (17.3") diagonal screen housed in the durable chassis of the new HP ZBook 17. The new innovative design projects a professional image and remains easy enough to carry where work takes you.Consolidate workstation resources and connect from any computer at any location with internet access. With HP Remote Graphics Software (RGS) collaborate with colleagues or utilize the power of servers and workstations back at the office. -
Power to perform
With Thunderbolt , professional NVIDIA Quadro 3D Graphics, and optional Quad Core CPUs, the new HP ZBook 17 takes power to a new standard.Empower your creativity. Count on dynamic, true workstation performance with the latest 4th generation Intel Core i5 or i7 processors.Customize this HP ZBook 17 to meet your demands. Keep large files at your fingertips without sacrificing performance with Windows 8 Pro, up to 2.75 TB of storage and up to 32 GB of memory.Accelerate creative projects with up to 2X faster data transfer speeds than USB 3.0. Easily connect to multiple devices with just one cable. Thunderbolt technology makes it possible.Get full power of graphics when you need them and longer battery life when using lighter graphic applications. It's automatic and seamless with hybrid graphics. -
Confidence in colors
Maintain accurate, predictable colors that are consistent across your entire digital workflow. What you see on your display is true to the finished product, thanks to the optional HP DreamColor display. -
Workstation reliability
During the HP Total Test Process, mobile workstations experience 115,000 hours of performance trials, and with ISV-certifications, the HP ZBook 17 is reliable and ready for business.Optimize this HP ZBook 17 for peak performance. HP Performance Advisor configures your system with updated settings and drivers to help maximize performance.No tools needed. Just unlatch the HP Easy Access Door to quickly service your hardware and upgrade parts.
- HP ZBook 17 Mobile Workstation - 17.3" - Intel Core i7 4600M - vPro - 4 GB RAM - 500 GB HDD
- Product Type
- Mobile workstation
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8 Pro) + Windows 8 Pro Licence
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i7 (4th Gen) 4600M / 2.9 GHz (3.6 GHz) / 4 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 17.3" LED backlight 1600 x 900 / HD+
- Graphics
- NVIDIA Quadro K610M
- Video Memory
- 1 GB GDDR5 SDRAM
- Input Device
- Keyboard, touchpad, pointing stick
- Numeric Keypad
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 8-cell
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, smart card reader
- Graphite, hematite
- 41.6 cm x 27.2 cm x 3.4 cm
- 3.46 kg
- Localisation
- Limited warranty - parts and labour - 3 years
- Product Type
- Recommended Use
- Small business, corporate business
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro) + Windows 8 Pro Licence
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Chipset
- Intel QM87
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 7200 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM removable - tray
Display
- 17.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1600 x 900 (HD+)
- Widescreen
- Image Aspect Ratio
- 16:9
- HD+ standard-viewing angle (SVA) anti-glare
Audio & Video
- Graphics Processor
- Video Memory
- 1 GB GDDR5 SDRAM
- Video System Features
- NVIDIA Optimus
- Sound
- Stereo speakers, microphone
- Codec
- IDT 92HD91
- High Definition Audio, DTS Studio Sound
Input
- Numeric Keypad
- Volume control, spill-resistant, touchpad with gesture support
Communications
- Wireless
- Wireless Controller
- Intel Centrino Advanced-N 6235
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I217-LM
- Remote Management Protocol
- SNMP 2
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
- Technology
- 8-cell Lithium Ion
- Installed Qty
- 1
- Max Supported Qty
- 2
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 19.5 V
Connections & Expansion
- Expansion Bays
- 1 x Upgrade Bay
- Slots
- 1 x ExpressCard/54 (1 free)
- VGA , DisplayPort , Thunderbolt , Headphone/microphone combo jack , LAN , 3 x USB 3.0 , USB 2.0 , Battery , Dock
- Memory Card Reader
- Yes (SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP SoftPaq Download Manager (free download), HP Hotkey Support, PDF Complete Corporate Edition, HP Performance Advisor, HP Spare Key, HP Peak Power Manager (free download), HP Client Security, Microsoft Office 2013 (Trial), HP Systems Software Manager (free download)
- Case Material
- Magnesium-aluminum alloy
- Dockable
- Security
- Security lock slot (cable lock sold separately), Intel Anti-Theft Technology (iAT), HP DuraFinish, Enhanced Pre-Boot Security, HP SpareKey, One-Step Logon, HP DuraCase, HP DisplaySafe, HP SureStart
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC
- Localization
- 3.46 kg
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance
- 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
- Vibration Tolerance
- 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
