Get the performance of a desktop with the freedom of a laptop. Get relentless performance when editing multiple streams of content, manipulating data and developing in VR.
Extreme performance to meet extraordinary demands
The HP ZBook 17 is packed with up to 50% more cores gen over gen, 10 TB storage, 64 GB memory and NVIDIA Quadro P5200 graphics. And with 20% better thermals, it will stay cool and quiet even under intense multi-application workloads. -
Pixel perfect display
Create stunning visuals with one billion colors on the HP DreamColor 4K display. With an integrated color calibration system and 100% Adobe RGB, your colors will be vibrant and accurate every single time. -
HP's most expandable laptop, no tools required
The ZBook 17 can be customized to meet any demand. And when your technology needs to evolve, you can upgrade storage or memory in seconds without tools.
- HP ZBook 17 G5 Mobile Workstation - 17.3" - Xeon E-2186M - 32 GB RAM - 512 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro for Workstations 64-bit - English
- Processor
- Intel Xeon E-2186M / 2.9 GHz (4.8 GHz) / 12 MB Cache
- Memory
- 32 GB DDR4 (2 x 16 GB)
- Storage
- 512 GB SSD NVMe, TLC
- Optical Drive
- No optical drive
- Display
- 17.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro P3200
- Video Memory
- 6 GB GDDR5 SDRAM
- Input Device
- Pointing stick, ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Networking
- 802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
- Battery
- 6-cell
- Ambient light sensor
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Turbo silver
- 41.6 cm x 28.8 cm x 3.35 cm
- 3.2 kg
- Localisation
- Limited warranty - parts and labour - 3 years
- Product Type
- Notebook
- Operating System
- Windows 10 Pro for Workstations 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.8 GHz
- Number of Cores
- 6-core
- Cache
- L3 - 12 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM246
- Platform Technology
- Intel vPro Technology
- Intel Turbo Boost Technology 2.0, Intel Optane Memory Supported
- RAM
- 32 GB (2 x 16 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM - ECC
- Speed
- 2666 MHz
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 4
- Empty Slots
- 2
Storage
- Main Storage
- 512 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe), triple-level cell (TLC)
- RAID Level
- RAID 0, RAID 1
Display
- 17.3" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 300 cd/m²
- 72% sRGB colour gamut, Full HD eDP anti-glare
- Keyboard Name
- HP Premium Collaboration Keyboard
Audio & Video
- Graphics Processor
- Video Memory
- 6 GB GDDR5 SDRAM
- Video System Features
- Shader Model 5.0
- Sound
- Stereo speakers
- High Definition Audio
- Audio Features
- Bang & Olufsen Audio, HP Clear Sound Amp
Input
- Keyboard, pointing stick, ClickPad
- Keyboard Layout
- UK
- Numeric Keypad
- Volume control, spill-resistant, ClickPad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Wireless-AC 9560 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
- Remote Management Protocol
- SNMP 2
- Miracast, Wake-on-LAN (WOL)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 6-cell lithium polymer
- Capacity
- 95.6 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 200 Watt, 19.5 V
Connections & Expansion
- 2 x USB 3.0 , USB 3.0 (charging) , LAN , Mini DisplayPort , HDMI , 2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort 1.3 , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
- Software Included
- Skype, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Windows Defender, Device Access Manager, HP Velocity, HP Security Manager, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP 3D DriveGuard, HP Mobile Connect Pro, HP Image Assistant, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP System Software Manager (free download), HP BIOSphere Gen4, HP Host Based MAC Address Manager, HP SureStart Gen4
- Turbo silver
- Case Material
- Aluminum, magnesium alloy
- Integrated Options
- Security
- HP DuraKeys, Automatic DriveLock, HP DriveLock, Measured Boot, Power On Authentication, Pre-boot Authentication, Master Boot Record Security, BIOS Update via Network, HP Sure Click
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, FCC, RoHS, WEEE, low halogen
- Localization
- 3.2 kg
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Software applications
Bundle includes:
Microsoft Office Home & Business 2019 Box Pack (Medialess, 1 PC, One Time Purchase) worth £191.34 | in stock |
£2,396.50
saving £8.33
saving £8.33
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£2,312.66
