HP Zbook 17 G5 Core i7-8750H 8GB 1TB 17" Windows 10 Pro
Quicklinx: DVDDWS00 Mfr#: 2ZC43ET#ABU
  • Core i7
  • IEEE 802.11n
Get the performance of a desktop with the freedom of a laptop. Get relentless performance when editing multiple streams of content, manipulating data and developing in VR.
  • Windows 10 Pro for workstations
    Be productive in any situation. Windows 10 Pro and powerful security, collaboration, and connectivity features from HP help you power through your day on the HP ZBook 17.
  • VR-ready
    Experience enhanced visualization and develop life-like VR experiences on-the-go with the latest NVIDIA Quadro P5200 graphics card.
  • Software certified
    Work with confidence knowing your HP ZBook 17 has been tested and certified for peak performance with leading software applications from Adobe, Autodesk, SolidWorks and more.
  • Industry-leading security
    Protect your work with HP Sure View that activates a privacy screen at the touch of a button and RAID 1 that keeps a backup copy of all your files in case you ever need it.
  • 8th gen Intel Core i9 or Intel Xeon processors
    Do more at once with next-gen 6-core Intel processors designed to handle complex, multi-threaded apps like Adobe Premier Pro and fast core clock and boost with Autodesk 3ds Max.
  • Industry-leading reliability
    Confidently take your work on-location knowing your ZBook 17 was built for 24 x 7 x 365 workloads and passed 14 rigorous military standard tests like shock, drop and dust.
HP ZBook 17 G5 Mobile Workstation - 17.3" - Intel Core i7 8750H - 8 GB RAM - 1 TB HDD - UK
Mobile workstation
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
1 TB HDD / 7200 rpm + 16 GB SSD cache (M.2) (3D Xpoint (Optane))
Display
17.3" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 630
Input Device
Keyboard, pointing stick, ClickPad
Keyboard
Keyboard Backlight
Numeric Keypad
802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
6-cell
Ambient light sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Turbo silver
41.6 cm x 28.8 cm x 3.35 cm
3.2 kg
Limited warranty - parts and labour - 3 years
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
Cache
L3 - 9 MB
64-bit Computing
Intel Turbo Boost Technology 2.0, Intel Optane Memory Supported
RAM
8 GB (1 x 8 GB)
Max RAM Supported
64 GB
DDR4 SDRAM - non-ECC
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
4
Empty Slots
3
Storage
Main Storage
1 TB HDD SATA 6Gb/s / 7200 rpm
SSD Cache
16 GB 3D Xpoint (Optane) (M.2)
RAID Level
RAID 0, RAID 1
Display
17.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
300 cd/m²
Colour Gamut
72% sRGB
Full HD eDP anti-glare
Keyboard Name
HP Premium Collaboration Keyboard
Audio & Video
Graphics Processor
Sound
Stereo speakers, dual array microphone
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio, HP Clear Sound Amp
Input
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Volume control, spill-resistant, ClickPad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wireless-AC 9560 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Remote Management Protocol
SNMP 2
Miracast, Wake-on-LAN (WOL), dual stream (2x2)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
6-cell lithium polymer
95.6 Wh
AC Adapter
Input
Output
200 Watt, 19.5 V
Connections & Expansion
2 x USB 3.0 , USB 3.0 (charging) , LAN , Mini DisplayPort , HDMI , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort 1.3 Alt Mode) , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
Skype, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Windows Defender, Device Access Manager, HP Velocity, HP Security Manager, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP 3D DriveGuard, HP Mobile Connect Pro, HP Image Assistant, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP System Software Manager (free download), HP BIOSphere Gen4, HP Host Based MAC Address Manager, HP SureStart Gen4
Turbo silver
Case Material
Aluminum, magnesium alloy
Integrated Options
Security
HP DuraKeys, Automatic DriveLock, HP DriveLock, Measured Boot, Power On Authentication, Pre-boot Authentication, Master Boot Record Security, BIOS Update via Network, HP Sure Click
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, FCC, RoHS, WEEE, low halogen
Localization
3.2 kg
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
