HP Zbook 17 G5 Core i7-8750H 8GB 1TB 17" Windows 10 Pro
Quicklinx: DVDDWS00 Mfr#: 2ZC43ET#ABU
  • Core i7
  • IEEE 802.11n
Get the performance of a desktop with the freedom of a laptop. Get relentless performance when editing multiple streams of content, manipulating data and developing in VR.
  • Extreme performance to meet extraordinary demands
    The HP ZBook 17 is packed with up to 50% more cores gen over gen, 10 TB storage, 64 GB memory and NVIDIA Quadro P5200 graphics. And with 20% better thermals, it will stay cool and quiet even under intense multi-application workloads.
  • Pixel perfect display
    Create stunning visuals with one billion colors on the HP DreamColor 4K display. With an integrated color calibration system and 100% Adobe RGB, your colors will be vibrant and accurate every single time.
  • HP's most expandable laptop, no tools required
    The ZBook 17 can be customized to meet any demand. And when your technology needs to evolve, you can upgrade storage or memory in seconds without tools.
HP ZBook 17 G5 Mobile Workstation - 17.3" - Core i7 8750H - 8 GB RAM - 1 TB HDD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
1 TB HDD / 7200 rpm + 16 GB SSD cache (M.2) (3D Xpoint (Optane))
Optical Drive
No optical drive
Display
17.3" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 630
Input Device
Pointing stick, ClickPad
Keyboard
Keyboard Backlight
Numeric Keypad
802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
6-cell
Ambient light sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Turbo silver
41.6 cm x 28.8 cm x 3.35 cm
3.2 kg
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
Cache
L3 - 9 MB
64-bit Computing
Intel Turbo Boost Technology 2.0, Intel Optane Memory Supported
RAM
8 GB (1 x 8 GB)
Max RAM Supported
64 GB
DDR4 SDRAM - non-ECC
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
4
Empty Slots
3
Storage
Main Storage
1 TB HDD SATA 6Gb/s / 7200 rpm
SSD Cache
16 GB 3D Xpoint (Optane) (M.2)
RAID Level
RAID 0, RAID 1
Display
17.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
300 cd/m²
72% sRGB colour gamut, Full HD eDP anti-glare
Keyboard Name
HP Premium Collaboration Keyboard
Audio & Video
Graphics Processor
Sound
Stereo speakers, dual array microphone
High Definition Audio
Audio Features
Bang & Olufsen Audio, HP Clear Sound Amp
Input
Keyboard, pointing stick, ClickPad
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Volume control, spill-resistant, ClickPad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wireless-AC 9560 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Remote Management Protocol
SNMP 2
Miracast, Wake-on-LAN (WOL), dual stream (2x2)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
6-cell lithium polymer
95.6 Wh
AC Adapter
Input
Output
200 Watt, 19.5 V
Connections & Expansion
2 x USB 3.0 , USB 3.0 (charging) , LAN , Mini DisplayPort , HDMI , 2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort 1.3 , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
Skype, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Windows Defender, Device Access Manager, HP Velocity, HP Security Manager, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP 3D DriveGuard, HP Mobile Connect Pro, HP Image Assistant, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP System Software Manager (free download), HP BIOSphere Gen4, HP Host Based MAC Address Manager, HP SureStart Gen4
Turbo silver
Case Material
Aluminum, magnesium alloy
Integrated Options
Security
HP DuraKeys, Automatic DriveLock, HP DriveLock, Measured Boot, Power On Authentication, Pre-boot Authentication, Master Boot Record Security, BIOS Update via Network, HP Sure Click
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, FCC, RoHS, WEEE, low halogen
Localization
3.2 kg
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
