HP ZBook 17 G4 Core i7-7820 16GB 1TB SSD 17.3" Windows 10 Pro
Quicklinx: DPZPWS00 Mfr#: 1RQ80EA#ABU
  • Core i7
  • IEEE 802.11n
We built desktop workstation power, performance and expandability into a device designed for the road. Made for mobile creative and design professionals with the most demanding projects, where compromise is simply not an option.
  • Extreme power and expandability
    Our most powerful mobile workstation is designed for demanding workloads. Configure your HP ZBook 17 with the latest Intel Xeon processors, NVIDIA Quadro or AMD Radeon Pro graphics, up to 4 TB of storage and dual Thunderbolt 3 ports.
  • No compromise reliability
    Confidently take on your workday with our durable & reliable HP ZBook 17. With a 3-year onsite limited warranty, 120,000 hours of testing, and 30 years of HP Z DNA this is where the fusion of innovation, performance & reliability meet.
HP ZBook 17 G4 Mobile Workstation - 17.3" - Core i7 7820HQ - 16 GB RAM - 256 GB SSD + 1 TB HDD - UK
Mobile workstation
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (7th Gen) 7820HQ / 2.9 GHz (3.9 GHz) / 8 MB Cache
16 GB DDR4 (2 x 8 GB)
Storage
256 GB SSD - HP Z Turbo Drive G2, TLC + 1 TB HDD / 7200 rpm
Display
17.3" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro P3000 / Intel HD Graphics 630
Video Memory
6 GB GDDR5 SDRAM
Input Device
Keyboard, touchpad, pointing stick
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
6-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Space Silver
42 cm x 28 cm x 3.3 cm
3.14 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Chipset
Mobile Intel CM238
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (2 x 8 GB)
Max RAM Supported
64 GB
DDR4 SDRAM - non-ECC
Speed
2400 MHz / PC4-19200
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
4
Empty Slots
2
Storage
Main Storage
256 GB SSD PCIe - HP Z Turbo Drive G2, triple-level cell (TLC)
Secondary Storage
1 TB HDD SATA / 7200 rpm
Display
17.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Multi-Stream transport (MST), Full HD ultra wide-viewing angle (UWVA) anti-glare
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
6 GB GDDR5 SDRAM
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
720p HD movie recording, low light enhancement
Sound
Stereo speakers, two microphones
Codec
CX7501
High Definition Audio
Audio Features
Bang & Olufsen Audio
Input
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Wake-on-LAN (WOL), dual stream (2x2)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.3ae, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 4.2
6-cell Lithium Ion
96 Wh
AC Adapter
Input
Output
200 Watt, 19.5 V
Connections & Expansion
VGA , HDMI , 2 x Thunderbolt 3 , Headphone/microphone combo jack , LAN , 3 x USB 3.0 , USB 3.0 (charging)
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
Fingerprint Software, Skype, LANDesk Management Suite, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Windows Defender, Device Access Manager, HP Velocity, HP Secure Erase, HP Security Manager, HP Manageability, CyberLink Power Media Player, HP Client Catalog, Absolute Persistence, HP Driver Packs, HP BIOS Config Utility, HP Touchpoint Manager, HP 3D DriveGuard, HP Mobile Connect Pro, HP Image Assistant, HP JumpStart, HP Sure Connect, HP Workwise, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP BIOSphere Gen3, Native Miracast
Space Silver
Case Material
Aluminum, magnesium alloy
Security
HP 3D DriveGuard, HP DuraKeys, One-Step Logon, HP BIOS Protection, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
Localization
3.14 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
DPZP HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack In Stock £13.44
DPZP HP Dual Head Keyed Cable Lock In Stock £43.00
DPZP HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £149.29
Other bundles (7)
DPZP HPE HDMI to DVI Adapter In Stock £9.89
DPZP HP USB-C To VGA Adapter In Stock £22.68
DPZP HP USB Travel Mouse In Stock £9.99
DPZP HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
DPZP HP Premium Wireless Mouse In Stock £38.00
DPZP HP USB-C to DisplayPort Adapter In Stock £23.53
DPZP HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor In Stock £150.00
