HP ZBook 17 G4 Core i7-7700 16GB 256GB SSD 17.3" Windows 10 Pro
Quicklinx: DPZNWS00 Mfr#: 1RQ79ET#ABU
  • Core i7
  • IEEE 802.11n
We built desktop workstation power, performance and expandability into a device designed for the road. Made for mobile creative and design professionals with the most demanding projects, where compromise is simply not an option.
  • Latest Operating Systems
    Be productive in any situation. Windows 10 Pro and powerful security, collaboration, and connectivity features from HP help you power through your day on the HP ZBook 17.
  • 7th Gen Intel Core and Xeon Processors
    Choose from 7th generation Intel Core 3 or Intel Xeon processor options that bring speed and superior performance to the HP ZBook 17.
  • Professional 3D graphics
    For real-time visualization of multi-layered files and projects, experience AMD Radeon Pro or NVIDIA Quadro 3D graphics with up to 16 GB of video memory.
  • High speed memory
    Extremely responsive experience with heavy workloads and file sizes with up to 64 GB DDR4 memory. Plus, help protect your data with optional ECC memory.
  • Ultra-fast storage
    Reduce boot up, file transfers and application load times by revolutionizing how your HP ZBook handles large files with 4 TB storage, including the optional dual HP Z Turbo Drives.
  • Make connections
    Quickly and easily transfer data and connect to devices. This HP ZBook 17 is packed with multiple ports including HDMI 2.0, USB 3.0, and dual Thunderbolt 3 ports.
HP ZBook 17 G4 Mobile Workstation - 17.3" - Intel Core i7 - 7700HQ - 16 GB RAM - 256 GB SSD - UK
Mobile workstation
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (7th Gen) - 7700HQ / 2.8 GHz, up to 3.8 GHz / 6 MB Cache
16 GB DDR4 (2 x 8 GB)
Storage
256 GB SSD - NVMe, HP Turbo Drive G2, TLC
Display
17.3" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro M2200 / Intel HD Graphics 630
Video Memory
4 GB GDDR5 SDRAM
Input Device
Keyboard, touchpad, pointing stick
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
6-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Space Silver
42 cm x 28 cm x 3.3 cm
3.14 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (7th Gen) 7700HQ / 2.8 GHz
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Chipset
Mobile Intel CM238
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (2 x 8 GB)
Max RAM Supported
64 GB
DDR4 SDRAM - non-ECC
Speed
2400 MHz / PC4-19200
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
4
Empty Slots
2
Storage
Main Storage
256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), HP Turbo Drive G2, triple-level cell (TLC)
Display
17.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Multi-Stream transport (MST), Full HD ultra wide-viewing angle (UWVA) anti-glare
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
720p HD movie recording, low light enhancement
Sound
Stereo speakers, two microphones
Codec
CX7501
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Wake-on-LAN (WOL), dual stream (2x2)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.3ae, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 4.2
6-cell Lithium Ion
96 Wh
AC Adapter
Input
Output
200 Watt, 19.5 V
Connections & Expansion
Interfaces Details
VGA , HDMI , 2 x Thunderbolt 3 , Headphone/microphone combo jack , LAN , 3 x USB 3.0 , USB 3.0 (charging)
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
Fingerprint Software, Skype, LANDesk Management Suite, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Windows Defender, Device Access Manager, HP Velocity, HP Secure Erase, HP Security Manager, HP Manageability, CyberLink Power Media Player, HP Client Catalog, Absolute Persistence, HP Driver Packs, HP BIOS Config Utility, HP Touchpoint Manager, HP 3D DriveGuard, HP Mobile Connect Pro, HP Image Assistant, HP JumpStart, HP Sure Connect, HP Workwise, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP BIOSphere Gen3, Native Miracast
Space Silver
Case Material
Aluminum, magnesium alloy
Security
HP 3D DriveGuard, HP DuraKeys, One-Step Logon, HP BIOS Protection, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
Localization
3.14 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
