HP ZBook 17 G2 Mobile Workstation Intel Core i7 4910MQ 16GB 512
Quicklinx: CP63WS00 Mfr#: M4R73EA#ABU
Type: Laptop
Display Size: 17.3in
Processor Model: I7-4910MQ
Operating System: Microsoft Windows 7 Professional 64-bit Edition
Installed Memory: 16GB
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
  • BD-RE
£4,353.99 ex VAT
£5,224.78 inc VAT
On the go creativity knows no limits with a vivid 43,94 cm (17.3") diagonal HP ZBook 17 G2. Showcase your best work in the office or on the go and take advantage of HP's most powerful processing, graphics, simple scalability, and blazing-fast connectivity to perform and collaborate at the speed of creativity.
Refuse to limit your potential
Experience the ultimate in mobile workstation performance with the HP ZBook 17 G2.
One workstation for the office and the field
At the office or on the go the 43,94 cm (17.3") diagonal HP ZBook 17 G2 provides a scalable solution to workstation computing and remains easy enough to take where work sends you.
Be color confident
What you see is what you get with the optional HP DreamColor display on the HP ZBook 17 G2.1 Maintain accurate, predictable colors that are true to the finished product and consistent across your entire digital workflow.
  • Refuse to limit your potential
  • One workstation for the office and the field
  • Be color confident
    What you see is what you get with the optional HP DreamColor display on the HP ZBook 17 G2. Maintain accurate, predictable colors that are true to the finished product and consistent across your entire digital workflow.
HP ZBook 17 G2 Mobile Workstation - 17.3" - Core i7 4910MQ - vPro - 16 GB RAM - 256 GB (2x) SSD + 512 GB SSD - UK
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro) + Windows 10 Pro Licence - English
Platform Technology
Intel vPro Platform
Intel Core i7 (4th Gen) 4910MQ / 2.9 GHz (3.9 GHz) / 8 MB Cache
16 GB DDR3L (2 x 8 GB)
Storage
1.024 TB: 2 x 256 GB SSD - HP Z Turbo Drive + 512 GB SSD
Optical Drive
Blu-ray Writer
Display
17.3" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro K4100M / Intel HD Graphics 4600
Video Memory
4 GB GDDR5 SDRAM
Input Device
Pointing stick
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
8-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Graphite, hematite
41.6 cm x 27.2 cm x 3.4 cm
3.46 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - carry-in , Limited warranty - battery - 3 years
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence - English
Processor / Chipset
CPU
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Chipset
Intel QM87
Platform Technology
Intel vPro Platform
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (2 x 8 GB)
Max RAM Supported
32 GB
DDR3L SDRAM
Speed
1600 MHz / PC3-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
4
Empty Slots
2
Storage
Total Capacity
1.024 TB
Main Storage
2 x 256 GB SSD M.2 PCIe - HP Z Turbo Drive
Secondary Storage
512 GB SSD SATA 6Gb/s
Optical Drive
BD-RE removable - tray
Display
17.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Full HD ultra wide-viewing angle (UWVA) anti-glare DreamColor, Multi-Stream transport (MST)
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Video System Features
NVIDIA Optimus, Shader Model 5.0
Camera
Yes - 1280 x 720
Camera Features
720p HD movie recording, low light enhancement
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD91
High Definition Audio, DTS Studio Sound, DTS SOUND+
Input
Keyboard, touchpad, pointing stick
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7260 - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I217-LM
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
8-cell Lithium Ion
Installed Qty
1
Max Supported Qty
2
75 Wh
AC Adapter
Input
Output
200 Watt, 19.5 V
Connections & Expansion
Expansion Bays
1 x Upgrade Bay
Slots
1 x ExpressCard/54 (1 free)
VGA , DisplayPort , Thunderbolt 2 , Headphone/microphone combo jack , Battery , Dock , LAN , 3 x USB 3.0 , USB 2.0
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, HP Performance Advisor, CyberLink YouCam BE, Foxit PhantomPDF Express, Device Access Manager with Just In Time Authentication, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, Box.net 50GB storage, HP Manageability, HP Validity Fingerprint Driver, HP Client Security Manager
Graphite, hematite
Case Material
Aluminum, magnesium alloy
Dockable
Security
Security lock slot (cable lock sold separately), Intel Anti-Theft Technology (iAT), HP 3D DriveGuard, Intel Active Management Technology (iAMT), HP DuraFinish, HP SpareKey, One-Step Logon, HP File Sanitizer, HP DuraCase, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC
Localization
3.46 kg
ENERGY STAR Certified
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
HP ZBook 17 G2 Mobile Workstation Intel Core i7 4910MQ 16GB 512 Bundle deal on HP ZBook 17 G2 Mobile Workstation Intel Core i7 4910MQ 16GB 512
Bundle includes:
Microsoft Office Home & Business 2019 - Digital Download Microsoft Office Home & Business 2019 - Digital Download worth £191.37 | in stock
Poly BLACKWIRE 5220 C5220 USB-A WW Poly BLACKWIRE 5220 C5220 USB-A WW worth £57.08 | in stock
£4,582.44
saving £20.00
Bundle includes:
Microsoft Office 365 Business Standard - Digital Download (1 year) Microsoft Office 365 Business Standard - Digital Download (1 year) worth £98.13 | in stock
£4,494.20
saving £15.00
Essential Accessories (4)
Get more from your purchase from one of our essential accessories
CP63 HP Docking Station Cable Lock In Stock £38.22
CP63 HP Combination Lock In Stock £22.54
CP63 HP Dual Head Keyed Cable Lock In Stock £43.00
CP63 HP 17.3 Business Slim Top Load Carrying Case In Stock £23.53
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
CP63 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site In Stock £68.17
Other bundles (14)
CP63 HPE DisplayPort to HDMI Adapter In Stock £13.56
CP63 HP Wireless Mobile Mouse (Comfort Grip) In Stock £26.00
CP63 HP 3-button USB Laser Mouse In Stock £11.00
CP63 HPE DisplayPort to VGA Adapter In Stock £15.14
CP63 HP USB-C To VGA Adapter In Stock £22.93
CP63 HP Business Headset V2 In Stock £15.55
CP63 HP - Disk drive - DVD-RW - USB - External In Stock £39.68
CP63 HP Wireless link-5 Keyboard In Stock £34.82
CP63 HP Presenter MouseRemote control In Stock £74.35
CP63 HP Premium Wireless Mouse In Stock £38.58
CP63 HP Essential USB Mouse In Stock £12.00
CP63 HP 3-button USB Laser Mouse In Stock £11.15
CP63 HP Premium Wired Mouse In Stock £21.33
CP63 HP USB-C to DisplayPort Adapter In Stock £23.53
Type: Laptop
Hard Drive Capacity: 1.024TB
Optical Storage: BD-RE
Graphics: NVIDIA Quadro K4100M / Intel HD Graphics 4600
Hard Drive Type: SSD
Brand: HP
Price Range Ex VAT: £1500+
