HP ZBook 17 G2 Intel Core i7-4710MQ 8GB 256GB SSD 17.3" Windows 7 Professional 64-bit
Quicklinx: BHTRWS00 Mfr#: J9A20EA#ABU
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
On the go creativity knows no limits with a vivid 43,94 cm (17.3") diagonal HP ZBook 17 G2. Showcase your best work in the office or on the go and take advantage of HP's most powerful processing, graphics, simple scalability, and blazing-fast connectivity to perform and collaborate at the speed of creativity.
  • Refuse to limit your potential
    Experience the ultimate in mobile workstation performance with the HP ZBook 17 G2.
  • One workstation for the office and the field
    At the office or on the go the 43,94 cm (17.3") diagonal HP ZBook 17 G2 provides a scalable solution to workstation computing and remains easy enough to take where work sends you.
  • Be color confident
    What you see is what you get with the optional HP DreamColor display on the HP ZBook 17 G2. Maintain accurate, predictable colors that are true to the finished product and consistent across your entire digital workflow.
HP ZBook 17 G2 Mobile Workstation - 17.3" - Intel Core i7 - 4710MQ - 8 GB RAM - 256 GB SSD - UK
Mobile workstation
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Intel Core i7 (4th Gen) - 4710MQ / 2.5 GHz, up to 3.5 GHz / 6 MB Cache
8 GB DDR3L
Storage
256 GB SSD - TCG Opal Encryption 2
Optical Drive
DVD SuperMulti
Display
17.3" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro K2200M
Video Memory
2 GB GDDR5 SDRAM
Input Device
Keyboard, touchpad, pointing stick
Keyboard
Numeric Keypad
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
8-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Graphite, hematite
41.6 cm x 27.2 cm x 3.4 cm
3.41 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site , Limited warranty - battery - 3 years
Mobile workstation
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
CPU
Intel Core i7 (4th Gen) 4710MQ / 2.5 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Chipset
Intel QM87
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB
Max RAM Supported
32 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
4
Storage
Main Storage
256 GB SSD SATA 6Gb/s - TCG Opal Encryption 2
Optical Drive
DVD±RW (±R DL) / DVD-RAM removable - tray
Display
17.3"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Full HD wide-viewing angle (WVA) anti-glare
Audio & Video
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Video System Features
NVIDIA Optimus
Camera
Yes - 1280 x 720
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD91
High Definition Audio, DTS Studio Sound
Input
Keyboard Layout
Numeric Keypad
Volume control, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7260 - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I217-LM
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
8-cell Lithium Ion
Max Supported Qty
2
75 Wh
AC Adapter
Input
Output
200 Watt, 19.5 V
Connections & Expansion
Expansion Bays
1 x Upgrade Bay
Slots
1 x ExpressCard/54 (1 free)
VGA , DisplayPort , Thunderbolt 2 , Headphone/microphone combo jack , LAN , 3 x USB 3.0 , USB 2.0 , Battery , Dock
Memory Card Reader
Yes (SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, HP Performance Advisor, CyberLink YouCam BE, Foxit PhantomPDF Express, HP Spare Key, Device Access Manager with Just In Time Authentication, HP Systems Software Manager (free download), HP PageLift, Box.net 50GB storage, HP Manageability, HP Validity Fingerprint Driver, HP Client Security Manager
Graphite, hematite
Case Material
Magnesium-aluminum alloy
Dockable
Security
Security lock slot (cable lock sold separately), Intel Anti-Theft Technology (iAT), HP 3D DriveGuard, HP DuraFinish, Enhanced Pre-Boot Security, HP SpareKey, One-Step Logon, HP File Sanitizer, HP DuraCase, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC
Localization
3.41 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
