HP ZBook 15U i76500U 15.6 16GB 256GB SSD W10P
Quicklinx: CN5RWS00 Mfr#: T7W14ET#ABU
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
Enjoy workstation performance in a low cost, compact package. The HP ZBook 15u with its 39,6 cm (15.6") diagonal display is the perfect combination of mobility and cost.
Ready to work from anywhere
Inspiration can strike any time-be ready with a Workstation that starts at 1,9 kg (4.18 lbs.), 19.9 mm thin and offers an optional touch screen, integrated numeric keypad, and impressive battery life.
Innovate on the fly
If it's value in a lightweight design you want, look no further. This workstation can be configured with up to 32 GB memory, AMD FirePro professional graphics, HP Z Turbo Drive G2, 1.5 TB of total storage, and a FHD touch display.
Defined by HP Z DNA
Work confidently with HP Mobile Workstations designed around 30 years of HP Z DNA with extensive ISV certification. It's reliable, designed to pass MIL-STD 810G testing, and endure 120K hours of testing with HP's Total Test Process.
  • Ready to work from anywhere
  • Innovate on the fly
  • Defined by HP Z DNA
HP ZBook 15u G3 Mobile Workstation - 15.6" - Core i7 6500U - 16 GB RAM - 256 GB SSD - UK
Ultrabook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Intel Core i7 (6th Gen) 6500U / 2.5 GHz (3.1 GHz) / 4 MB Cache
16 GB DDR4 (1 x 16 GB)
Storage
256 GB SSD HP Z Turbo Drive
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
AMD FirePro W4190M / Intel HD Graphics 520
Video Memory
2 GB GDDR5 SDRAM
Input Device
Pointing stick
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, NFC, Bluetooth 4.2, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, smart card reader
Space Silver
38.33 cm x 25.77 cm x 1.99 cm
1.89 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Ultrabook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Platform Technology
Intel vPro Technology
Enhanced SpeedStep technology, Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (1 x 16 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2) PCIe - HP Z Turbo Drive
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Multi-Stream transport (MST), Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Video System Features
AMD Enduro technology
Camera
Yes - 1280 x 720
Camera Features
720p HD movie recording, low light enhancement
Sound
Stereo speakers, two microphones
Codec
CX7501
High Definition Audio
Audio Features
Bang & Olufsen Audio
Input
Keyboard, touchpad, pointing stick
Keyboard Layout
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8260 - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Remote Management Protocol
SNMP 2
Miracast, Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell Lithium Ion
46 Wh
AC Adapter
Input
Output
65 Watt, 18.5 V
Connections & Expansion
Slots
1 x SIM card (1 free)
VGA , DisplayPort , 2 x USB 3.0 , USB 3.1 , Dock , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC UHS-II Card)
Software
Software Included
HP Recovery Disc Creator, Skype, LANDesk Management Suite, Microsoft Security Essentials, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, HP Performance Advisor, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, HP Spare Key, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP Security Manager, HP GPS and Location, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Noise Reduction Software, HP Image Assistant
Space Silver
Case Material
Aluminum, magnesium alloy
Dockable
Security
HP 3D DriveGuard, HP DuraKeys, HP SpareKey, soft-touch surface, HP BIOS Protection, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, KCC, A-Tick, ICES
Localization
1.89 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
