Finally, workstation-class power meets thin and light design for executives on-the-go. With advanced features like quad core Intel Core processors and 3D professional graphics, you can view and edit high resolution files from anywhere.
Windows 10 Pro
Be productive in any situation with the power and security of Windows 10 Pro, enhanced with best-in-class collaboration and connectivity features from HP. -
AMD 3D Radeon Pro Graphics
Work with professional, certified discrete graphics for rich visual immersion and real-time visualization of complex, multi-layered files and projects. -
Quad-core Intel Core processors
Work at the speed of your ideas with the premium performance of the latest quad core Intel Core processors, and up to 4.2 GHz of turbo boost at your fingertips. -
Software Certification
HP mobile workstations undergo dozens of tests for software certification and optimized performance with the industry's leading software providers like Autodesk, Adobe, and more. -
4K Anti-Glare Display
Work seamlessly on airplanes, trains or in cafes with a stunning optional 4K display, with anti-glare technology that improves the outdoor and direct light experience. -
HP Premium Collaboration Keyboard
Easily connect and collaborate with Skype and other conferencing tools. Conference key shortcuts include start/end call, view calendar, mute, and screen sharing.
- HP ZBook 15u G5 Mobile Workstation - 15.6" - Intel Core i7 - 8550U - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (8th Gen) - 8550U / 1.8 GHz, up to 4 GHz / 8 MB Cache
- Memory
- 16 GB DDR4 (1 x 16 GB)
- Storage
- 512 GB SSD - NVMe
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- AMD Radeon Pro WX 3100 / Intel UHD Graphics 620
- Video Memory
- 2 GB
- Input Device
- Keyboard, pointing stick, ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 3-cell
- Dockable
- Security
- Fingerprint reader, smart card reader
- Turbo silver
- 37.08 cm x 25.1 cm x 1.86 cm
- 1.77 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (8th Gen) 8550U / 1.8 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 16 GB (1 x 16 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2400 MHz / PC4-19200
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe - NVM Express (NVMe)
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 340 cd/m²
- Full HD eDP anti-glare
Audio & Video
- Graphics Processor
- Video Memory
- 2 GB
- Camera
- Yes - 720p
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- 720p HD movie recording, IR camera, low light enhancement, Windows Hello
- Sound
- Stereo speakers, dual array microphone
- High Definition Audio
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard Layout
- UK
- Volume control, spill-resistant, multi-touch clickpad
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-V
- Remote Management Protocol
- SNMP 2
- Wake-on-LAN (WOL), dual stream (2x2)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 3-cell
- Capacity
- 50 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- USB 3.0 (charging) , USB-C 3.1 (supports Thunderbolt 3, DisplayPort Alt Mode) , USB 3.0 , Headphone/microphone combo jack , LAN , Dock
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
- Software Included
- Skype, LANDesk Management Suite, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Password Manager, Windows Defender, Device Access Manager, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP Security Manager, HP BIOS Configuration Utility (free download), HP Credential Manager, HP Client Catalogue (free download), Absolute Persistence, HP Driver Packs, HP 3D DriveGuard 6, HP Image Assistant, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP BIOSphere Gen3, Native Miracast, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP Workwise (free download), CyberLink Power Media Player CMIT, HP Fingerprint Sensor, Power On Authentication
- Turbo silver
- Case Material
- Aluminum
- Dockable
- Security
- HP 3D DriveGuard, HP DuraKeys, soft-touch surface, HP BIOS Protection, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3, Master Boot Record Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, KCC, WEEE, A-Tick, ICES, Common Criteria EAL4+, low halogen
- Localization
- 1.77 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (5)
Get more from your purchase from one of our essential accessories
HP 65W Smart AC Adapter | In Stock | £18.31 |
HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack | In Stock | £13.44 |
HP Dual Head Keyed Cable Lock | In Stock | £43.00 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £147.06 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £206.71 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site | In Stock | £123.80 |
Other bundles (6)
HP USB-C To VGA Adapter | In Stock | £22.68 |
HP USB Travel Mouse | In Stock | £10.14 |
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP Premium Wireless Mouse | In Stock | £38.00 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £144.44 |
