HP ZBook 15u G5 Core i7-8550U 16GB 512GB SSD 15.6" Windows 10 Pro
Quicklinx: DWZYWS00 Mfr#: 2ZC06ET#ABU
Display Size: 15.6in
Processor Model: I7-8550U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB
Hard Drive Capacity: 512GB
  • Core i7
  • IEEE 802.11n
£1,589.57 ex VAT
£1,907.48 inc VAT
Finally, workstation-class power meets thin and light design for executives on-the-go. With advanced features like quad core Intel Core processors and 3D professional graphics, you can view and edit high resolution files from anywhere.
  • Premium power
    Power through your day using everything from spreadsheets to CAD with blazing fast HP Z Turbo Drive high speed storage and certified AMD Radeon Pro graphics.
  • Advanced protection from the inside out
    Industry-leading security features help keep your files and privacy safe while traveling. Optional HP Sure View guards your screen from prying eyes and HP Sure Click protects web browsing with hardware-enforced security.
HP ZBook 15u G5 Mobile Workstation - 15.6" - Core i7 8550U - 16 GB RAM - 512 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) 8550U / 1.8 GHz (4 GHz) / 8 MB Cache
16 GB DDR4 (1 x 16 GB)
Storage
512 GB SSD NVMe
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
AMD Radeon Pro WX 3100 / Intel HD Graphics 620
Video Memory
2 GB
Input Device
Pointing stick, ClickPad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell
Dockable
Security
Fingerprint reader, smart card reader
Turbo silver
37.08 cm x 25.1 cm x 1.86 cm
1.77 kg
Environmental Standards
TCO Certified Notebooks 5, ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
16 GB (1 x 16 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2400 MHz / PC4-19200
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
512 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe)
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
340 cd/m²
Full HD eDP anti-glare
Audio & Video
Graphics Processor
Video Memory
2 GB
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
720p HD movie recording, IR camera, low light enhancement, Windows Hello
Sound
Stereo speakers, dual array microphone
High Definition Audio
Audio Features
Bang & Olufsen Audio
Input
Keyboard, pointing stick, ClickPad
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, multi-touch clickpad
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL), dual stream (2x2)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell
50 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V
Connections & Expansion
USB 3.0 (charging) , USB-C 3.1/Thunderbolt 3/DisplayPort , USB 3.0 , Headphone/microphone combo jack , LAN , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
Skype, LANDesk Management Suite, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Performance Advisor, Password Manager, Windows Defender, Device Access Manager, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP Security Manager, HP BIOS Configuration Utility (free download), HP Credential Manager, HP Client Catalogue (free download), Absolute Persistence, HP Driver Packs, HP 3D DriveGuard 6, HP Image Assistant, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP LAN-WLAN Protection, HP Client Security Suite Gen3, HP BIOSphere Gen3, Native Miracast, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP Workwise (free download), CyberLink Power Media Player CMIT, HP Fingerprint Sensor, Power On Authentication
Turbo silver
Case Material
Aluminum
Dockable
Security
HP 3D DriveGuard, HP DuraKeys, soft-touch surface, HP BIOS Protection, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3, Master Boot Record Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, KCC, WEEE, A-Tick, ICES, Common Criteria EAL4+, low halogen
Localization
1.77 kg
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP ZBook 15u G5 Core i7-8550U 16GB 512GB SSD 15.6 Bundle deal on HP ZBook 15u G5 Core i7-8550U 16GB 512GB SSD 15.6" Windows 10 Pro
£1,769.15
saving £2.42
£1,688.74
Optical Storage: None
Graphics: AMD Radeon Pro WX 3100 / Intel HD Graphics 620
Hard Drive Type: SSD
Type: Laptop
Brand: HP
Price Range Ex VAT: 1500+
