HP Zbook 15u G3 Intel Core i7-6500U 8GB 500GB 15.6" Windows 10 Professional 64-bit
Quicklinx: C26MWS00 Mfr#: T7W11ET#ABU
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
Enjoy workstation performance in a low cost, compact package. The HP ZBook 15u with its 39,6 cm (15.6") diagonal display is the perfect combination of mobility and cost.
  • Choose the OS for you
    Support your unique user needs with a choice of Windows 10 Pro or Windows 7 operating systems.
  • Innovate anywhere
    The ZBook 15u Mobile Workstation delivers sleek Ultrabook style, impressive performance, and long battery life.
  • New powerful processors
    Get powerful performance from new 6th Gen Intel Core processors.
  • Professional-grade graphics
    Take advantage of the rich features of ISV certified AMD FirePro 3D graphics with 2GB of video memory designed to work with professional applications on the HP ZBook 15u Mobile Workstation.
  • Work smarter
    Take on challenging tasks with confidence with up to 32 GB DDR4 memory.
  • Ultra-fast storage
    Reduce boot up, calculation, and response times by revolutionizing how your HP ZBook handles large files with the optional HP Z Turbo Drive G2, a remarkably fast and innovative storage solution.
HP ZBook 15u G3 Mobile Workstation - 15.6" - Intel Core i7 - 6500U - 8 GB RAM - 1 TB HDD - UK
Mobile workstation
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Intel Core i7 (6th Gen) - 6500U / 2.5 GHz, up to 3.1 GHz / 4 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
1 TB HDD / 5400 rpm
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
AMD FirePro W4190M / Intel HD Graphics 520
Video Memory
2 GB GDDR5 SDRAM
Input Device
Keyboard, touchpad, pointing stick
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, NFC, Bluetooth 4.2, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, smart card reader
Space Silver
38.33 cm x 25.77 cm x 1.99 cm
1.89 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - parts and labour - 3 years
Mobile workstation
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
CPU
Intel Core i7 (6th Gen) 6500U / 2.5 GHz
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
1 TB HDD SATA 6Gb/s / 5400 rpm
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Multi-Stream transport (MST), Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Video System Features
AMD Enduro technology
Camera
Yes - 1280 x 720
Camera Features
720p HD movie recording, low light enhancement
Sound
Stereo speakers, two microphones
Codec
CX7501
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8260 - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Remote Management Protocol
SNMP 2
Miracast, Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell lithium polymer
46 Wh
AC Adapter
Input
Output
65 Watt, 18.5 V
Connections & Expansion
Slots
1 x SIM card (1 free)
Interfaces Details
VGA , DisplayPort , 2 x USB 3.0 , USB 3.1 , Dock , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC UHS-II Card)
Software
Software Included
HP Recovery Disc Creator, Skype, LANDesk Management Suite, Microsoft Security Essentials, HP Remote Graphics Software, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, HP Performance Advisor, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, HP Spare Key, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP Security Manager, HP GPS and Location, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Noise Reduction Software, HP Image Assistant
Space Silver
Case Material
Aluminum, magnesium alloy
Dockable
Security
HP 3D DriveGuard, HP DuraKeys, HP SpareKey, soft-touch surface, HP BIOS Protection, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, KCC, A-Tick, ICES
Localization
1.89 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
