HP ZBook 15u G2 Intel Core i5-5200U 4GB 500GB 15.6" Windows 7 Professional 64-bit
Quicklinx: BJNCWS00 Mfr#: J8Z84ET#ABU
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
in stock
£1,114.19 ex VAT
£1,337.02 inc VAT
Create anywhere using HP's ZBook workstation Ultrabook in a 39,6 cm (15.6") diagonal screen size. This customizable workstation delivers impressive professional 3D graphics and outstanding performance even from the most demanding applications. All in all, an unprecedented sleek and stylish design.
  • Scale up to what you need
    Customize the HP ZBook G2 to meet your demands. Keep large files at your fingertips without sacrificing performance with two internal storage devices with up to 1.25 TB storage and 16 GB memory.
  • Set a new performance curve for your Zbook 15u
    Handle large files, reduce work time and increase performance with the HP Z Turbo Drive.
  • Professional-grade graphics
    Take advantage of the rich features of ISV certified AMD FirePro graphics designed to work with the most demanding applications on the HP ZBook G2 Mobile Workstation.
  • Make connections
    Quickly and easily transfer data and connect to devices. This mobile workstation is packed with multiple ports including four USB 3.0 ports, DisplayPort 1.2, media card slot and more.
  • Brighten your work
    See clearly no matter what light you're in with an optional stylish backlit keyboard.
  • Work virtually anywhere
    Access and share your workstation or server-based graphic-rich applications from any PC, thin client or Windows tablet with HP Remote Graphics Software.
HP ZBook 15u G2 Mobile Workstation - 15.6" - Intel Core i5 - 5200U - 4 GB RAM - 500 GB HDD - UK
Mobile workstation
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Intel Core i5 (5th Gen) - 5200U / 2.2 GHz, up to 2.7 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 5500
Input Device
Keyboard, touchpad, pointing stick
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, NFC, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Graphite, hematite
37.55 cm x 25.36 cm x 2.142 cm
1.91 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - carry-in , Limited warranty - battery - 3 years
Mobile workstation
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
CPU
Intel Core i5 (5th Gen) 5200U / 2.2 GHz
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 7200 rpm
Display
15.6" - TN
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Full HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720
Camera Features
720p HD movie recording
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD91
High Definition Audio, DTS Studio Sound, DTS SOUND+
Input
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7265 - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-LM
Remote Management Protocol
SNMP 2
Intel Wireless Display (WiDi), Miracast, Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell lithium polymer
Max Supported Qty
2
50 Wh
AC Adapter
Input
Output
65 Watt, 18.5 V
Connections & Expansion
VGA , DisplayPort , 4 x USB 3.0 , LAN , Dock , Battery , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC UHS-II Card)
Software
Software Included
Drivers & Utilities, LANDesk Management Suite, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, HP Performance Advisor, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Windows Defender, HP Registration, HP Mobile Connect, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, HP Security Manager, HP Disk Sanitizer External Edition (free download), HP BIOSphere, HP Wireless Hotspot, HP Client Catalog, HP Roaming Alert, HP Driver Packs, HP BIOS Config Utility, HP CIK for Microsoft SCCM, HP Device Access Manager
Graphite, hematite
Case Material
Aluminum, magnesium alloy
Dockable
Security
HP 3D DriveGuard, HP DuraFinish, One-Step Logon, HP File Sanitizer, HP DuraCase, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, KCC, A-Tick, ICES
Localization
1.91 kg
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
