HP ZBook 15u Core i5-7200U 8GB 256GB SSD 15.6" Windows 10 Pro
Quicklinx: DWZWWS00 Mfr#: 2ZC04EA#ABU
Display Size: 15.6in
Processor Model: I5-7200U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
Hurry, only 1 left in stock!
£1,249.20 ex VAT
£1,499.04 inc VAT
Finally, workstation-class power meets thin and light design for executives on-the-go. With advanced features like quad core Intel Core processors and 3D professional graphics, you can view and edit high resolution files from anywhere.
  • Premium power
    Power through your day using everything from spreadsheets to CAD with blazing fast HP Z Turbo Drive high speed storage and certified AMD Radeon Pro graphics.
  • Advanced protection from the inside out
    Industry-leading security features help keep your files and privacy safe while traveling. Optional HP Sure View guards your screen from prying eyes and HP Sure Click protects web browsing with hardware-enforced security.
HP ZBook 15u G5 Mobile Workstation - 15.6" - Core i5 7200U - 8 GB RAM - 256 GB SSD - QWERTY UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB - M.2 2280 SSD NVMe
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
AMD Radeon Pro WX 3100 / Intel HD Graphics 620
Video Memory
2 GB
Input Device
Pointing stick, ClickPad
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
Turbo silver
37.08 cm x 25.1 cm x 1.86 cm
1.77 kg
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Smart Cache, Intel Burst Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2133 MHz / PC4-19200 - 2400 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe)
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
340 cd/m²
Slim Design, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, 157 ppi
Keyboard Name
HP Collaboration
Audio & Video
Graphics Processor
Video Memory
2 GB
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
720p HD movie recording, IR camera, low light enhancement, Windows Hello
Sound
Stereo speakers, dual array microphone
High Definition Audio
Audio Features
Bang & Olufsen Audio
Input
Keyboard, pointing stick, ClickPad
Keyboard Backlight
Keyboard Layout
QWERTY UK
Numeric Keypad
Spill-resistant, multi-touch clickpad
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell lithium polymer
AC Adapter
Input
Output
65 Watt, 19.5 V
Connections & Expansion
USB 3.0 (charging) , Thunderbolt 3 , USB 3.0 , Headphone/microphone combo jack , LAN , HDMI , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Turbo silver
Case Material
Aluminum
Dockable
Security
HP DuraKeys, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3, Master Boot Record Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES
Localization
1.77 kg
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP ZBook 15u Core i5-7200U 8GB 256GB SSD 15.6 Bundle deal on HP ZBook 15u Core i5-7200U 8GB 256GB SSD 15.6" Windows 10 Pro
£1,436.84
saving £8.33
£1,348.96
Optical Storage: None
Graphics: AMD Radeon Pro WX 3100 / Intel HD Graphics 620
Hard Drive Type: SSD
Type: Laptop
Brand: HP
Price Range Ex VAT: 1000 - 1500
