Work almost anywhere on the HP ZBook 15 mobile workstation. Its mobility and robust configurability, create a powerful mix of style, features, and portability in a thin, light, 39,6 cm (15.6") diagonal form factor.
Choose the OS for you
Support your unique user needs with a choice of Windows 10 Pro or Windows 7 operating systems. -
Innovate anywhere
The HP ZBook 15 mobile workstation delivers sleek style, impressive performance, and long battery life. -
New powerful processors
Get powerful performance from 6th Gen Intel Core or Intel Xeon processor options. -
Professional-grade graphics
Take advantage of the rich features of ISV certified AMD FirePro 3D graphics with 2GB of video memory designed to work with the most demanding applications on the HP ZBook 15 G3 Mobile Workstation. -
Work smarter
Take on challenging tasks with confidence in the up to 64 GB DDR with optional ECC memory for no compromise capacity, performance and reliability. -
Ultra-fast storage
Reduce boot up, calculation, and response times by revolutionizing how your HP ZBook handles large files with the optional dual HP Z Turbo Drives, a remarkably fast and innovative storage solution.
- HP ZBook 15 G3 Mobile Workstation - 15.6" - Intel Xeon - E3-1505MV5 - 16 GB RAM - 256 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Processor
- Intel Xeon E3-1505MV5 / 2.8 GHz, up to 3.7 GHz / 8 MB Cache
- Memory
- 16 GB DDR4 (2 x 8 GB)
- Storage
- 256 GB SSD - HP Z Turbo Drive
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro M1000M
- Video Memory
- 2 GB GDDR5 SDRAM
- Input Device
- Keyboard, touchpad, pointing stick
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 9-cell
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, smart card reader
- Space Silver
- 38.6 cm x 26.4 cm x 2.6 cm
- 2.59 kg
- Localisation
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM236 Express
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 16 GB (2 x 8 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM - ECC
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 4
- Empty Slots
- 2
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - HP Z Turbo Drive
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Multi-Stream transport (MST), Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, Panel Self Refresh (PSR)
Audio & Video
- Graphics Processor
- Video Memory
- 2 GB GDDR5 SDRAM
- Video System Features
- NVIDIA Optimus, Shader Model 5.0
- Camera
- Yes - 1280 x 720
- Camera Features
- 720p HD movie recording, low light enhancement
- Sound
- Stereo speakers, two microphones
- Codec
- CX7501
- High Definition Audio, DTS Studio Sound, DTS SOUND+
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard Layout
- UK
- Numeric Keypad
- Volume control, spill-resistant, touchpad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
- Remote Management Protocol
- SNMP 2
- Wake-on-LAN (WOL)
- IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
- Technology
- 9-cell lithium polymer
- Capacity
- 90 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 150 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- VGA , HDMI , 2 x Thunderbolt 3 , Headphone/microphone combo jack , LAN , 3 x USB 3.0
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
- Software Included
- Drivers & Utilities, Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP SoftPaq Download Manager (free download), HP ePrint, HP Setup, HP Hotkey Support, PDF Complete Corporate Edition, HP Performance Advisor, Microsoft Internet Explorer 9.0, CyberLink YouCam BE, HP Wallpaper, HP Spare Key, Password Manager, Microsoft Internet Explorer 10, HP Peak Power Manager (free download), HP Client Security, Device Access Manager with Just In Time Authentication, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, HP File Sanitizer, Box.net 50GB storage, HP Trust Circles Standard, Privacy Manager (free download), HP Disk Sanitizer, HP Ceement, HP Manageability, HP Wireless Button Driver, HP Validity Fingerprint Driver, HP Software Setup, HP Client Security Manager, HP 3D DriveGuard
- Space Silver
- Case Material
- Aluminum, magnesium alloy
- Security
- HP DuraKeys, One-Step Logon, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port, Pre-boot Authentication
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, WEEE, A-Tick, ICES, Common Criteria EAL4+, KC
- Localization
- 2.59 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
