HP Zbook 15 Studio x360 Core i7-8750H 8GB 256GB SSD 15.6" Windows 10 Pro
Quicklinx: DVD8WS00 Mfr#: 2ZC59ET#ABU
  • Core i7
  • IEEE 802.11n
Reimagine your creative process with a versatile laptop that gives you the latest convertible design you'll want with the pro-grade performance you need.
  • Windows Pro for workstations
    Be productive in any situation. Windows 10 Pro and powerful security, collaboration, and connectivity features from HP help you power through your day on the HP ZBook Studio x360.
  • HP ZBook x360 Pen
    Create on the go with the professional Wacom AES pen featuring 4K pressure sensitive levels, tilt and two customizable buttons.
  • 15.6" diagonal touch display
    Take your work outdoors with the anti-glare touch display and built in ambient light sensor that dims or brightens based on your surroundings.
  • Fast charging and long battery life
    Take your work on the road with up to 16 hours of battery life for maximum productivity. When you need it, recharge ultra-fast (50% in just 45 minutes).
  • Blazing fast storage
    Create seamlessly. Save and access large files locally with up to 4TB local NVMe storage, up to 21 times faster than standard HDD storage and six times faster than SATA SSD.
  • 8th Gen Intel Core i9 or Intel Xeon processors
    Do more at once with next-generation six-core Intel Core i9 or Intel Xeon processors designed to handle complex, multi-threaded applications like Adobe Premier Pro.
HP ZBook Studio x360 G5 Mobile Workstation - 15.6" - Intel Core i7 8750H - 8 GB RAM - 256 GB SSD - UK
Mobile workstation - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
8 GB DDR4 (2 x 4 GB)
Storage
256 GB SSD - TLC + 16 GB SSD cache (3D Xpoint (Optane))
Display
15.6" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro P1000
Video Memory
4 GB GDDR5 SDRAM
Input Device
Keyboard, ClickPad
Keyboard
Keyboard Backlight
802.11a/b/g/n/ac, Bluetooth 5.0
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
36 cm x 25.4 cm x 2.04 cm
2.22 kg
Limited warranty - parts and labour - 3 years
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
Cache
L3 - 9 MB
64-bit Computing
Chipset
Mobile Intel CM246
Intel Turbo Boost Technology 2.0
RAM
8 GB (2 x 4 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
256 GB SSD 2.5" SATA - triple-level cell (TLC)
SSD Cache
16 GB 3D Xpoint (Optane)
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
400 cd/m²
Ambient light sensor, Corning Gorilla glass 4
Keyboard Name
HP Collaboration
Audio & Video
Graphics Processor
NVIDIA Quadro P1000
Video Memory
4 GB GDDR5 SDRAM
Video System Features
NVIDIA Optimus, Shader Model 5.0
Sound
Stereo speakers
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio, HP Clear Sound Amp
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, multi-gesture clickpad
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560 - PCI Express Mini Card (M.2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
4-cell lithium polymer
Installed Qty
1
64 Wh
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
Slots
2 x M.2 Card (1 free)
2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort 1.3 Alt Mode) , USB 3.0 (charging) , USB 3.0 , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
HP Remote Graphics Software, HP Performance Advisor, Windows Defender, Device Access Manager, HP Secure Erase, HP Security Manager, HP Drive Packs (free download), HP Client Catalog, HP BIOS Config Utility, HP Manageability & Integration Kit (free download), HP System Software Manager (free download), HP BIOSphere Gen4
Security
Power-on password, One-Step Logon, Setup Password, HP Automatic Drive Lock, HP DriveLock, Measured Boot, Power On Authentication, HP Fast Charge, Pre-boot Authentication, HP Sure Start Gen 4, HP Sure Recover, BIOS Update via Network, HP Sure Click
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
Localization
2.22 kg
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
