HP Zbook 15 Studio x360 Core i7-8750H 8GB 256GB SSD 15.6" Windows 10 Pro
Quicklinx: DVD8WS00 Mfr#: 2ZC59ET#ABU
Display Size: 15.6in
Processor Model: I7-8750H
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i7
  • IEEE 802.11n
£2,221.48 ex VAT
£2,665.77 inc VAT
Reimagine your creative process with a versatile laptop that gives you the latest convertible design you'll want with the pro-grade performance you need.
  • 360-degree pro performance
    Finally, a convertible laptop designed to tackle large files and run multiple apps with speed and responsiveness. Seamlessly edit or render high-res images without lag or delay, with NVIDIA Quadro graphics and 6-core Intel Xeon processors.
  • Precision-crafted versatility
    With our innovative 360-degree hinge, you'll get the comfort of a laptop, the convenience of a tablet and the luxury of additional modes to help you showcase your work.
  • Pixel-perfect tools
    Achieve remarkable inking precision with 4000 levels of pressure sensitivity and tilt with the Wacom AES pen. And with the HP DreamColor display, you'll experience one billion vibrant colors on HP's brightest 4K laptop.
HP ZBook Studio x360 G5 Mobile Workstation - 15.6" - Core i7 8750H - 8 GB RAM - 256 GB SSD - UK
Notebook - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
8 GB DDR4 (2 x 4 GB)
Storage
256 GB SSD TLC + 16 GB SSD cache (3D Xpoint (Optane))
Optical Drive
No optical drive
Display
15.6" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro P1000
Video Memory
4 GB GDDR5 SDRAM
Input Device
ClickPad
Keyboard
Keyboard Backlight
802.11a/b/g/n/ac, Bluetooth 5.0
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
36 cm x 25.4 cm x 2.04 cm
2.22 kg
Limited warranty - parts and labour - 3 years
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
Cache
L3 - 9 MB
64-bit Computing
Chipset
Mobile Intel CM246
Intel Turbo Boost Technology 2.0
RAM
8 GB (2 x 4 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
256 GB SSD - (2.5") SATA - triple-level cell (TLC)
SSD Cache
16 GB 3D Xpoint (Optane)
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
400 cd/m²
Ambient light sensor, Corning Gorilla glass 4
Keyboard Name
HP Collaboration
Audio & Video
Graphics Processor
NVIDIA Quadro P1000
Video Memory
4 GB GDDR5 SDRAM
Video System Features
NVIDIA Optimus, Shader Model 5.0
Sound
Stereo speakers
High Definition Audio
Audio Features
Bang & Olufsen Audio, HP Clear Sound Amp
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, multi-gesture clickpad
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560 - PCI Express Mini Card (M.2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
4-cell lithium polymer
Installed Qty
1
64 Wh
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
Slots
2 x M.2 Card (1 free)
2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort 1.3 , USB 3.0 (charging) , USB 3.0 , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
HP Remote Graphics Software, HP Performance Advisor, Windows Defender, Device Access Manager, HP Secure Erase, HP Security Manager, HP Drive Packs (free download), HP Client Catalog, HP BIOS Config Utility, HP Manageability & Integration Kit (free download), HP System Software Manager (free download), HP BIOSphere Gen4
Security
Power-on password, One-Step Logon, Setup Password, HP Automatic Drive Lock, HP DriveLock, Measured Boot, Power On Authentication, HP Fast Charge, Pre-boot Authentication, HP Sure Start Gen 4, HP Sure Recover, BIOS Update via Network, HP Sure Click
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
Localization
2.22 kg
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP Zbook 15 Studio x360 Core i7-8750H 8GB 256GB SSD 15.6 Bundle deal on HP Zbook 15 Studio x360 Core i7-8750H 8GB 256GB SSD 15.6" Windows 10 Pro
£2,403.64
saving £8.33
£2,320.65
Optical Storage: None
Graphics: NVIDIA Quadro P1000
Hard Drive Type: SSD
Touchscreen: Yes
Type: Laptop
Brand: HP
Price Range Ex VAT: 1500+
