HP Zbook 15 Studio Core i7-8750H 8GB 256GB SSD 15" Windows 10 P
Quicklinx: DVD7WS00 Mfr#: 2ZC50ET#ABU
Display Size: 15.6in
Processor Model: I7-8750H
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i7
  • IEEE 802.11n
£1,976.03 ex VAT
£2,371.23 inc VAT
Get the ultimate blend of design and performance in the next generation HP ZBook Studio. Speed through your work and bring your ideas to life on HP's brightest 4K laptop.
  • HP's brightest 4K laptop
    See your work in one billion vibrant colors on the HP DreamColor display with 600 nits of brightness. Master color-critical work with a built-in color calibration system that helps maintain perfect color every single time.
  • More powerful than ever before
    Get ultra-fast, 6-core Intel Xeon processors and enhanced thermals that keep your laptop cool and quiet. Render photorealistic images with certified NVIDIA Quadro graphics - optimized for stability and peak performance with leading software apps.
  • HP's most secure mobile workstation
    Protect your confidential work with security features like facial recognition and a webcam shutter. With HP Sure View privacy display, your screen becomes visible only to you at the touch of a button, so you can do private work in busy, open areas.
HP ZBook Studio G5 Mobile Workstation - 15.6" - Core i7 8750H - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro P1000 / Intel UHD Graphics 630
Video Memory
4 GB GDDR5 SDRAM
Input Device
ClickPad
Keyboard
Keyboard Backlight
802.11a/b/g/n/ac, Bluetooth 5.0
4-cell
Ambient light sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
36 cm x 25.4 cm x 1.74 cm
2 kg
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
Cache
9 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
DDR4 SDRAM
Speed
2666 MHz
Rated Speed
2666 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD SATA
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
400 cd/m²
Full HD eDP anti-glare
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Sound
Stereo speakers
High Definition Audio
Audio Features
Bang & Olufsen Audio
Input
Keyboard, ClickPad
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, gesture function
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wireless-AC 9560
IEEE 802.1x, IEEE 802.11i
4-cell Lithium Ion
64 Wh
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort 1.3 , USB 3.0 (charging) , USB 3.0 , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SDHC Card, SDXC Card, SDXC UHS-II Card)
Integrated Options
Security
Power-on password, One-Step Logon, Setup Password, Automatic DriveLock, BIOS Absolute Persistence, HP DriveLock, Measured Boot, Power On Authentication, Pre-boot Authentication, Secure Erase, HP Sure Start Gen 4, HP Sure Run, HP Sure Recover, BIOS Update via Network, HP Sure Click
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
Localization
2 kg
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP Zbook 15 Studio Core i7-8750H 8GB 256GB SSD 15 Bundle deal on HP Zbook 15 Studio Core i7-8750H 8GB 256GB SSD 15" Windows 10 P
£2,155.89
saving £3.64
£2,075.20
Optical Storage: None
Graphics: NVIDIA Quadro P1000 / Intel UHD Graphics 630
Hard Drive Type: SSD
Brand: HP
Price Range Ex VAT: 1500+
