Get the ultimate blend of design and performance in the next generation HP ZBook Studio. Speed through your work and bring your ideas to life on HP's brightest 4K laptop.
Windows 10 Pro for Workstations
Be productive in any situation. Windows 10 Pro and powerful security, collaboration, and connectivity features from HP help you power through your day on the HP ZBook Studio. -
8th gen Intel Core i9 or Intel Xeon processors
Do more at once with next-generation 6-core Intel Core i9 or Intel Xeon processors designed to handle complex, multi-threaded applications like Adobe Premier Pro. -
NVIDIA Quadro 3D Graphics
Seamlessly edit your designs and render multi-layered files with certified NVIDIA Quadro P2000 graphics, optimized for stability and performance with professional software apps. -
Blazing fast storage
Create seamlessly. Save and access large files locally with up to 4 TB local NVMe storage, up to 21 times faster than standard HDD storage and six times faster than SATA SSD. -
Large memory configurations
Get remarkable, real time performance running multiple applications simultaneously with up to 64 GB RAM. -
Fast charging and long battery life
Take your work on the road with up to 16 hours of battery life for maximum productivity. When you need it, recharge ultra-fast (50% in just 45 minutes).
- HP ZBook Studio G5 Mobile Workstation - 15.6" - Intel Core i7 8750H - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro P1000 / Intel UHD Graphics 630
- Video Memory
- 4 GB GDDR5 SDRAM
- Input Device
- Keyboard, ClickPad
- Keyboard
- UK
- Keyboard Backlight
- Networking
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Battery
- 4-cell
- Ambient light sensor
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- 36 cm x 25.4 cm x 1.74 cm
- 2 kg
- Localisation
- Limited warranty - parts and labour - 3 years
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- 6-core
- Cache
- 9 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Technology
- DDR4 SDRAM
- Speed
- 2666 MHz
- Rated Speed
- 2666 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD SATA
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 400 cd/m²
- Full HD eDP anti-glare
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 4 GB GDDR5 SDRAM
- Sound
- Stereo speakers
- High Definition Audio
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard Layout
- UK
- Volume control, spill-resistant, gesture function
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Wireless-AC 9560
- IEEE 802.1x, IEEE 802.11i
- Technology
- 4-cell Lithium Ion
- Capacity
- 64 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 150 Watt, 19.5 V
Connections & Expansion
- 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort 1.3 Alt Mode) , USB 3.0 (charging) , USB 3.0 , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SDHC Card, SDXC Card, SDXC UHS-II Card)
- Integrated Options
- Security
- Power-on password, One-Step Logon, Setup Password, Automatic DriveLock, BIOS Absolute Persistence, HP DriveLock, Measured Boot, Power On Authentication, Pre-boot Authentication, Secure Erase, HP Sure Start Gen 4, HP Sure Run, HP Sure Recover, BIOS Update via Network, HP Sure Click
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
- Localization
- 2 kg
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (5)
Get more from your purchase from one of our essential accessories
HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack | In Stock | £13.44 |
HP Dual Head Keyed Cable Lock | In Stock | £43.00 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £147.64 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £206.71 |
HP Travel Hub G2 Port replicator USB-C VGA, HDMI for Chromebook | In Stock | £40.61 |
Other bundles (7)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
HPE HDMI to DVI Adapter | In Stock | £9.89 |
HP USB Travel Mouse | In Stock | £10.03 |
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP Premium Wireless Mouse | In Stock | £38.00 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £150.00 |
