HP ZBook 15 Intel Core i76700HQ 15.6 16GB 512GB
Quicklinx: CP6BWS00 Mfr#: T7V49EA#ABU
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
Work almost anywhere on the HP ZBook 15 mobile workstation. Its mobility and robust configurability, create a powerful mix of style, features, and portability in a thin, light, 39,6 cm (15.6") diagonal form factor.
Impress and perform
HP's most popular mobile workstation has been redesigned, inside and out. Now 27% thinner and 7% lighter than the previous generation, it offers 100% more wow--it's designed to impress and perform.
Create your ideal workstation
Configure the HP ZBook 15 with Intel® Xeon® processor options, up to 64 GB ECC memory, dual 1 TB HP Z Turbo Drive G22 3 for up to 3 TB4 of total storage, dual Thunderbolt™ , and optional HP DreamColor UHD or FHD touch displays.
Defined by HP Z DNA
Work confidently with HP mobile workstations designed around 30 years of HP Z DNA with extensive ISV certification. It’s reliable, designed to pass MIL-STD 810G testing, and endure 120K hours of testing in HP's Total Test Process.
  • Choose the OS for you
    Support your unique user needs with a choice of Windows 10 Pro or Windows 7 operating systems.
  • Innovate anywhere
    The HP ZBook 15 mobile workstation delivers sleek style, impressive performance, and long battery life.
  • New powerful processors
    Get powerful performance from 6th Gen Intel Core or Intel Xeon processor options.
  • Professional-grade graphics
    Take advantage of the rich features of ISV certified AMD FirePro 3D graphics with 2GB of video memory designed to work with the most demanding applications on the HP ZBook 15 G3 Mobile Workstation.
  • Work smarter
    Take on challenging tasks with confidence in the up to 64 GB DDR with optional ECC memory for no compromise capacity, performance and reliability.
  • Ultra-fast storage
    Reduce boot up, calculation, and response times by revolutionizing how your HP ZBook handles large files with the optional dual HP Z Turbo Drives, a remarkably fast and innovative storage solution.
HP ZBook 15 G3 Mobile Workstation - 15.6" - Intel Core i7 - 6700HQ - 16 GB RAM - 512 GB SSD - UK
Mobile workstation
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache
16 GB DDR4 (2 x 8 GB)
Storage
512 GB SSD - HP Z Turbo Drive G2
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro M1000M / Intel HD Graphics 530
Video Memory
2 GB GDDR5 SDRAM
Input Device
Keyboard, touchpad, pointing stick
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
9-cell - up to 15.75 hours
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Space Silver
38.6 cm x 26.4 cm x 2.6 cm
2.59 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
Mobile workstation
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
CPU
Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
L3 - 6 MB
64-bit Computing
Chipset
Mobile Intel CM236 Express
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (2 x 8 GB)
Max RAM Supported
64 GB
DDR4 SDRAM - non-ECC
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
4
Empty Slots
2
Storage
Main Storage
512 GB SSD M.2 PCIe - HP Z Turbo Drive G2
RAID Level
RAID 0, RAID 1
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
300 cd/m²
Multi-Stream transport (MST), Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR, High Bit Rate 2 (HBR2)
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Video System Features
NVIDIA Optimus, Shader Model 5.0
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
720p HD movie recording, low light enhancement
Sound
Stereo speakers, two microphones
Codec
CX7501
High Definition Audio
Audio Features
Output: Bang & Olufsen Audio
Input
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
9-cell lithium polymer
90 Wh
Run Time
Up to 15.75 hours
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
Interfaces Details
LAN , VGA , 2 x USB 3.0 , HDMI , 2 x Thunderbolt 3 , Headphone/microphone combo jack , USB 3.0 (charging)
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, HP Performance Advisor, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, HP Spare Key, Password Manager, Windows Defender, One Step Logon, HP Client Security, HP Systems Software Manager (free download), HP Velocity, HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Credential Manager, HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Noise Reduction Software, HP Image Assistant (free download)
Space Silver
Case Material
Aluminum, magnesium alloy
Security
HP DuraKeys, One-Step Logon, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter, HDD carrier cage
ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+
Localization
2.59 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
CP6B HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack In Stock £13.44
CP6B HP Dual Head Keyed Cable Lock In Stock £43.00
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
CP6B HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site In Stock £94.03
Other bundles (7)
CP6B HPE HDMI to DVI Adapter In Stock £9.89
CP6B HP USB-C To VGA Adapter In Stock £22.68
CP6B HP USB Travel Mouse In Stock £10.14
CP6B HP X4000b Bluetooth Mouse In Stock £26.80
CP6B HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
CP6B HP Premium Wireless Mouse In Stock £38.00
CP6B HP USB-C to DisplayPort Adapter In Stock £23.53
