HP Zbook 15 Intel Core i7-6700HQ 500GB 8GB Win 10 pro
Quicklinx: C6PDWS00 Mfr#: T7V51EA#ABU
Type: Laptop
Display Size: 15.6in
Processor Model: I7-6700HQ
Operating System: Microsoft Windows 7 Professional 64-bit Edition
Installed Memory: 8GB
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
  • Bluetooth 4.0
£1,799.62 ex VAT
£2,159.54 inc VAT
Work almost anywhere on the HP ZBook 15 mobile workstation. Its mobility and robust configurability, create a powerful mix of style, features, and portability in a thin, light, 39,6 cm (15.6") diagonal form factor.
  • Impress and perform
    HP's most popular mobile workstation has been redesigned, inside and out. Now 27% thinner and 15% lighter than the previous generation, it offers 100% more wow-it's designed to impress and perform.
  • Create your ideal workstation
    Configure the HP ZBook 15 with an Intel Xeon processor, 64 GB ECC memory, mid-range NVIDIA Quadro or AMD FirePro professional graphics, dual HP Z Turbo Drives, 3 TB of total storage, dual Thunderbolt 3, and an optional HP DreamColor UHD display.
  • Defined by HP Z DNA
    Work confidently with HP mobile workstations designed around 30 years of HP Z DNA with extensive ISV certification. It's reliable, designed to pass MIL-STD 810G testing, and endure 120K hours in HP's Total Test Process.
HP ZBook 15 G3 Mobile Workstation - 15.6" - Core i7 6700HQ - 8 GB RAM - 1 TB HDD - UK
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz (3.5 GHz) / 6 MB Cache
8 GB DDR4 (2 x 4 GB)
Storage
1 TB HDD / 5400 rpm
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
AMD FirePro W5170M
Video Memory
2 GB GDDR5 SDRAM
Input Device
Pointing stick
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
9-cell
Security
Trusted Platform Module (TPM 1.2) Security Chip, smart card reader
Graphite, hematite
38.6 cm x 26.4 cm x 2.6 cm
2.59 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Chipset
Mobile Intel CM236 Express
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (2 x 4 GB)
Max RAM Supported
64 GB
DDR4 SDRAM - non-ECC
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
4
Empty Slots
2
Storage
Main Storage
1 TB HDD SATA 6Gb/s / 5400 rpm
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Multi-Stream transport (MST), Full HD standard-viewing angle (SVA) eDP anti-glare, Panel Self Refresh (PSR)
Audio & Video
Graphics Processor
AMD FirePro W5170M
Video Memory
2 GB GDDR5 SDRAM
Video System Features
Shader Model 5.0, AMD Enduro technology
Camera
Yes - 720p
Camera Features
720p HD movie recording, low light enhancement
Sound
Stereo speakers, two microphones
Codec
CX7501
High Definition Audio
Audio Features
Bang & Olufsen Audio
Input
Keyboard, touchpad, pointing stick
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
9-cell lithium polymer
90 Wh
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
LAN , VGA , 3 x USB 3.0 , HDMI , 2 x Thunderbolt 3 , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Software
Software Included
Drivers & Utilities, Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP SoftPaq Download Manager (free download), HP ePrint, HP Setup, HP Hotkey Support, PDF Complete Corporate Edition, HP Performance Advisor, Microsoft Internet Explorer 9.0, CyberLink YouCam BE, HP Wallpaper, HP Spare Key, Password Manager, Microsoft Internet Explorer 10, HP Peak Power Manager (free download), HP Client Security, Device Access Manager with Just In Time Authentication, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, HP File Sanitizer, Box.net 50GB storage, HP Trust Circles Standard, Privacy Manager (free download), HP Disk Sanitizer, HP Ceement, HP Manageability, HP Wireless Button Driver, HP Validity Fingerprint Driver, HP Software Setup, HP Client Security Manager, HP 3D DriveGuard
Graphite, hematite
Case Material
Aluminum, magnesium alloy
Security
HP DuraFinish, One-Step Logon, HP DuraCase, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, A-Tick, ICES, KC
Localization
2.59 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
HP Zbook 15 Intel Core i7-6700HQ 500GB 8GB Win 10 pro Bundle deal on HP Zbook 15 Intel Core i7-6700HQ 500GB 8GB Win 10 pro
Bundle includes:
Microsoft Office Home & Business 2019 - Digital Download Microsoft Office Home & Business 2019 - Digital Download worth £191.37 | in stock
Poly BLACKWIRE 5220 C5220 USB-A WW Poly BLACKWIRE 5220 C5220 USB-A WW worth £57.08 | in stock
£2,028.07
saving £20.00
Bundle includes:
Microsoft Office 365 Business Standard - Digital Download (1 year) Microsoft Office 365 Business Standard - Digital Download (1 year) worth £98.13 | in stock
£1,939.83
saving £15.00
Type: Laptop
Hard Drive Capacity: 1TB
Optical Storage: None
Graphics: AMD FirePro W5170M
Hard Drive Type: HDD
Touchscreen: No
Brand: HP
Price Range Ex VAT: £1500+
