HP ZBook 15 Intel Core i7-4710MQ Workstation 8GB 256GB SSD Windows 7 Professional (64-bit)
Quicklinx: C80NWS00 Mfr#: J8Z48ET#ABU
Display Size: 15.6in
Processor Model: I7-4710MQ
Operating System: Microsoft Windows 7 Professional 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
£1,978.73 ex VAT
£2,374.47 inc VAT
Be productive in the office or in the field. Take advantage of the HP ZBook 15 G2's powerful processing and graphics, simple scalability, and blazing-fast connectivity to perform and collaborate at the speed of creativity.
  • Work smarter
    Work anywhere and be confident the power you need is at your fingertips. The ZBook 15 G2 is our most versatile mobile workstation with Windows 8.1, Intel Core i5 or i7 processors professional graphics, and lasting battery life.
  • Feel the power
    Take performance to a new level on HP ZBook 15 G2 with optional Quad Core CPUs, Thunderbolt 2, HP Z Turbo Drive storage, and optional QHD+ display options.
  • Be professional
    Look stylish and confident carrying the HP ZBook 15 G2. Project a professional image at the office, client meetings, and on the road without sacrificing durability in a lightweight chassis.
HP ZBook 15 G2 Mobile Workstation - 15.6" - Core i7 4710MQ - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Intel Core i7 (4th Gen) 4710MQ / 2.5 GHz (3.5 GHz) / 6 MB Cache
8 GB DDR3L (2 x 4 GB)
Storage
256 GB - M.2 SSD HP Z Turbo Drive
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 3200 x 1800 / QHD+
Graphics
NVIDIA Quadro K2100M
Video Memory
2 GB GDDR5 SDRAM
Input Device
Pointing stick
Numeric Keypad
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
8-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Graphite, hematite
38.15 cm x 25.7 cm x 3.55 cm
2.78 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 3 years
Notebook
Recommended Use
Small business, corporate business
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Chipset
Mobile Intel QM87 Express
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache, Intel Smart Response Technology
RAM
8 GB (2 x 4 GB)
Max RAM Supported
32 GB
DDR3L SDRAM
Speed
1600 MHz / PC3-12800 - 1600 MHz
SO-DIMM 204-pin
Slots Qty
4
Empty Slots
2
Storage
Main Storage
256 GB SSD - (M.2) PCIe - HP Z Turbo Drive
RAID Level
RAID 0, RAID 1
Optical Drive
DVD±RW (±R DL) / DVD-RAM removable - tray
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
3200 x 1800 (QHD+)
Widescreen
Image Aspect Ratio
16:9
QHD ultra wide-viewing angle (UWVA) eDP anti-glare
Audio & Video
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Video System Features
NVIDIA Optimus, Shader Model 5.0
Camera
Yes - 1280 x 720
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD91
High Definition Audio, DTS Studio Sound, DTS SOUND+
Input
Keyboard, touchpad, pointing stick
Numeric Keypad
Volume control, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7260 - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I217-LM
Remote Management Protocol
SNMP 2
IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az
8-cell Lithium Ion
Installed Qty
1
Max Supported Qty
2
75 Wh
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
Expansion Bays
1 x Upgrade Bay
Slots
1 x ExpressCard/54
VGA , DisplayPort , Thunderbolt 2 , Headphone/microphone combo jack , Battery , Dock , 3 x USB 3.0 , USB 2.0 , LAN
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, HP Performance Advisor, CyberLink YouCam BE, Foxit PhantomPDF Express, HP Spare Key, One Step Logon, HP Client Security, Device Access Manager with Just In Time Authentication, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, HP File Sanitizer, Box.net 50GB storage, Drive Encryption, HP Manageability, HP Validity Fingerprint Driver, DigitalPersona Pro Workgroup
Graphite, hematite
Case Material
Magnesium-aluminum alloy
Dockable
Security
HP 3D DriveGuard, HP DuraFinish, HP DuraCase, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, FIPS 140-2, A-Tick, ICES, KC
Localization
2.78 kg
ENERGY STAR Certified
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP ZBook 15 Intel Core i7-4710MQ Workstation 8GB 256GB SSD Windows 7 Professional (64-bit) Bundle deal on HP ZBook 15 Intel Core i7-4710MQ Workstation 8GB 256GB SSD Windows 7 Professional (64-bit)
£2,165.19
saving £8.33
£2,078.49
Optical Storage: DVD±RW (±R DL) / DVD-RAM
Graphics: NVIDIA Quadro K2100M
Hard Drive Type: SSD
Touchscreen: No
Type: Laptop
Brand: HP
Price Range Ex VAT: 1500+
