HP Zbook 15 G5 Core i7-8850H 4GB 1TB 15" Windows 10 Pro
Quicklinx: DVDBWS00 Mfr#: 2ZC39ET#ABU
Display Size: 15.6in
Processor Model: I7-8750H
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 1TB
  • Core i7
  • IEEE 802.11n
40 in stock
£1,726.70 ex VAT
£2,072.04 inc VAT
Get extraordinary performance with industry-leading security packed into a mobile workstation designed to thrive with heavy rendering, engineering and simulation workflows.
  • Full-throttle performance
    Get blazing-fast performance with the heaviest multi-app workloads. Boost your speed on single and multi-threaded apps with the high-performance multi-core Intel processor. Through it all, our cutting-edge thermal design keeps everything cool and quiet.
  • Ready to expand
    When your technology needs evolve, you can easily upgrade. Simply remove the back panel and switch out your memory or storage in seconds.
  • Industry-leading security
    Advanced security features come standard on every ZBook 15. System safeguards like HP Client Security Suite and HP Sure Start - the industry's first self-healing BIOS - mean your device is locked down tight, so your data and identity are too.
HP ZBook 15 G5 Mobile Workstation - 15.6" - Core i7 8750H - 8 GB RAM - 1 TB HDD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
1 TB HDD / 7200 rpm + 16 GB SSD cache (M.2) (3D Xpoint (Optane))
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro P1000 / Intel UHD Graphics 630
Video Memory
4 GB GDDR5 SDRAM
Input Device
Pointing stick, ClickPad
Keyboard Backlight
Numeric Keypad
802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Turbo silver
37.6 cm x 26.4 cm x 2.6 cm
2.6 kg
Limited warranty - parts and labour - 3 years
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
Cache
L3 - 9 MB
64-bit Computing
Chipset
Mobile Intel CM246
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache, Intel Optane Memory Supported
RAM
8 GB (1 x 8 GB)
Max RAM Supported
64 GB
DDR4 SDRAM
Speed
2666 MHz - 2666 MHz
SO-DIMM 260-pin
Slots Qty
4
Empty Slots
3
Storage
Main Storage
1 TB HDD SATA 6Gb/s / 7200 rpm
SSD Cache
16 GB 3D Xpoint (Optane) (M.2)
RAID Level
RAID 0, RAID 1
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
220 cd/m²
Full HD eDP anti-glare
Keyboard Name
HP Premium Collaboration Keyboard
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Video System Features
NVIDIA Optimus, Shader Model 5.0
Sound
Stereo speakers, dual array microphone
High Definition Audio
Audio Features
Bang & Olufsen Audio, HP Clear Sound Amp
Input
Keyboard, pointing stick, ClickPad
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Volume control, spill-resistant, ClickPad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Wireless-AC 9560 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Remote Management Protocol
SNMP 2
Miracast, Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
4-cell lithium polymer
90 Wh
AC Adapter
Input
Output
150 Watt, 19.5 V
Connections & Expansion
LAN , USB 3.0 (charging) , HDMI , 2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort , Headphone/microphone combo jack , 2 x USB 3.0
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Turbo silver
Case Material
Aluminum, magnesium alloy
Security
HP DuraKeys, Automatic DriveLock, HP DriveLock, Measured Boot, Power On Authentication, Pre-boot Authentication, Master Boot Record Security, BIOS Update via Network, HP Sure Click
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, FCC, RoHS, WEEE, Common Criteria EAL4+, low halogen
Localization
2.6 kg
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP Zbook 15 G5 Core i7-8850H 4GB 1TB 15 Bundle deal on HP Zbook 15 G5 Core i7-8850H 4GB 1TB 15" Windows 10 Pro
£1,908.87
saving £8.33
£1,818.24
Optical Storage: None
Graphics: NVIDIA Quadro P1000 / Intel UHD Graphics 630
Hard Drive Type: HDD
Brand: HP
Price Range Ex VAT: 1500+
